Home > Technical > Horn problems |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1032 |
Hi all,
Has anyone had the issue that I have? When using the rear wash wipe the horn sounds! The horn works normally on the stalk but the rear wash fails to operate! Had a quick word at the main dealers last week when I took my wife's freelancer 2 in and they hadn't heard or experienced anything like it Thoughts and ides appreciated Greg Forgot to add 2011 Tdci usw |
2nd Feb 2015 12:24pm |
I've had it from new and not touched the wiring , it's only just happened in the last month!
2nd Feb 2015 1:28pm |
Then that's odd. Has it been in for any work at all?
2nd Feb 2015 1:30pm |
Nope nowt,
2nd Feb 2015 1:32pm |
In that case someone more electrically minded should be along soon
Ray |
2nd Feb 2015 1:35pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
That is really bizarre, you'd think it was an earth fault but I even think that the horn and rear wash wipe are in different fuse boxes.
The only other thing is that maybe there is a shorted wire somewhere, especially if the location as described above putting the looms for the rear wash and horn in the same place. Check for a mouse nest! I kid you not. My race car was suffering strange problems and we eventually found an old mouse nest at the back of the engine and they had chewed through some of the loom. What happens if you pull the Horn fuse out? On your model, I think it's Fuse 3 in the fuse box under the drivers seat. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Feb 2015 3:13pm |
Well finally got to the bottom of it! Chaffed wiring behind headlight , two wires chaffing on each other , sorted under extended warranty
17th Mar 2015 10:35pm |
