Home > Maintenance & Modifications > Someone pass me the dunce hat...
Crafty1980
So I had to change my wheel today... (nail... slow puncture)
In doing so, I managed to break all the teeth off the plastic "cap remover" tool while trying to remove all the caps off all the nuts holding the spare wheel on... including the ones that I have since learnt are actually permanently crimped on... Turns out that it's only the locking wheel nut cap that comes off... who knew?!?
In light of the fact that there is not a single note in the manual highlighting the fact that the non locking wheel nut caps are permanently crimped on, is this something that all defender owners have to learn the hard way at some point as some sort of "right of passage"?!?
...or do I now just feel a lot more stupid than I ever thought possible?!? Banging Head
Post #395128 2nd Feb 2015 2:30pm
mk1collector
Whistle Rolling with laughter
Post #395130 2nd Feb 2015 2:31pm
stanley
http://www.rimmerbros.co.uk/Item--i-ANR543...tAodznQAWg
Don't ask me how I know where you can replacements 😋
Post #395134 2nd Feb 2015 2:36pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
You mean that there is a tool for taking them off, what does it look like?
Edit, Embarassed should have looked at the link. I always thought that was some bit of plastic they put the key in. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #395135 2nd Feb 2015 2:39pm
And you breath the same air
Post #395139 2nd Feb 2015 2:58pm
Crafty1980
In my defence, your honour, all the caps look the same - regardless of being crimped on or not!
So how would anyone a) know which one to try and remove that's covering the locking nut and b) know that the others weren't removable?!
I bet I'm not the first for this to happen to them... nor will I be the last!! Big Cry
Post #395141 2nd Feb 2015 3:06pm
Laurie
The removable cap has a dimple in the middle.
The others are a permanent part of the wheelnut.
Post #395142 2nd Feb 2015 3:10pm
JWL
Ah the joys of alloy wheels, the only way I used to know which one was the locking one ,after they all had a dent in the top, was to put the socket on all of them until I came to the one that would leave me flat on my face when I went to give it a good snatch with the long bar Rolling Eyes
Post #395143 2nd Feb 2015 3:13pm
Crafty1980
Again, excellent and useful information! That would have been a perfect addition to the manual! Banging Head
Post #395144 2nd Feb 2015 3:22pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
found that out on my Disco 1. Oh my that was last century Shocked
Post #395174 2nd Feb 2015 5:40pm
The plastic thing doesn't really merit the description "tool" - it is rubbish!
I use the wheel brace itself to get the cap off, since with a little wiggling it will pull off the caps without any difficulty. My plastic "thing" went in the bin long ago.
I also use the wheel brace to push the caps back on, and then give them a further 30 degree turn to lock the cap solidly on the locking nut underneath. I have over the years lost several of the caps, usually when driving back from a main dealer service when the vehicle was under warranty and was main dealer serviced, because they are so loose and sloppy on the locking nuts. Since adopting the 30-degree-twist technique I haven't lost a single one (it is harder for someone to nick them too).
Post #395180 2nd Feb 2015 5:54pm
Crafty1980
So you're either showing your age or I'm showing my youthful naivety when it comes to the fact that this is my first! Razz
Post #395190 2nd Feb 2015 6:17pm
steventheplumber
I think its my age Rolling with laughter
Post #395381 3rd Feb 2015 9:36am
MartinK
+1 Thumbs Up
I use a good quality 27mm hex deep socket and breaker bar on the wheel nuts...same 27mm socket usefully fits the oil filter Thumbs Up The 27mm socket on it's own (without a wrench) is a good fit, and waggles the locking wheelnut cover off nae bother Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #395402 3rd Feb 2015 11:17am
Yup, 27mm across flats is the size.
On the road, I use a spider wrench to loosen, spin off, and spin on the nuts (and do the faffing around with the cover on the locking nut). I use a torque wrench and 27mm socket to tighten on refitting.
At home, it's much the same except I usually use a windy gun (air or electric) to spin off and and on, then set with the torque wrench.
Post #395407 3rd Feb 2015 11:47am
