![]() | Home > Maintenance & Modifications > Key mod |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Found the thread yesterday evening. 20 min of quality time with my Dremel and I now I have an all-in-1 key. Thanks for the instructions
-[Allan]- Member Since: 22 Mar 2014 Location: West Yorkshire Posts: 44 ![]() ![]() ![]() |
That's another mod to do added to the list.
Thanks for the write up ![]() |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 749 ![]() ![]() ![]() |
Anyone try this with the Puma sets?
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
That is absolutely brilliant!
A typical "Landy" approach to solving a problem that others charge good money for! I have a Puma, and will definitely be doing the same. Well done! Top mod!!! 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Works fine with Puma keys
Puma works too. Brilliant!
tt is worthwhile to make sure the remote casing clips together securely and that the area where the key tongue is attached is as solid as possible. The housing was not intended to be used to rotate an ignition cylinder. If the ignition lock engages, the force that is applied while rotating the wheel to free the lock should not be underestimated. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
The key exits below the clips so has no 'stress' effect on the top half and should be 'very' well glued into the base.
The mod can be done for under Ģ10 and you can always go back to orginal without issue. Just buy a spare case from ebay to cut up and use a 'cut' key from local key cutting place. Put your orginal key and case safe. You only need to the fob internals which swap over in seconds http://www.ebay.co.uk/itm/150977396204 |
As can be seen
![]() Click image to enlarge ![]() Click image to enlarge |
I also did a flip key but this has been my main key for over a year and has stood up well.
I did mine some months ago and one thing that is well worth mentioning is to make sure you have glued it in well. I have successfully used a hot glue gun but my first attempt looked all fine untill I went out to disarm the motor, the fob wouldn't work but when I parted the two halves it did. The pcb is very susceptable to anything touching it, even your fingers can stop it transmitting if they are touching it. I trimmed the cut out bit of the key, reglued it and all has been fine ever since.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
Thanks for the tutorial and ideas. Great mod. Did this today and it took about 20 minutes... Excellent!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Fish Member Since: 21 Jan 2014 Location: United Kingdom Posts: 58 ![]() ![]() ![]() |
Has anyone managed this for a new Puma key yet?..
You can buy them from http://www.remotekey.co.uk/land-rover/defender-2/ ready done, I've had one since May and use it as my primary key.
