Home > Maintenance & Modifications > Lower the Tow Ball height on a Defender 90
Brillo
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I ordered a 90 last week with a rear step bumper - STC 50269AA. The sales guy mentioned I may need a bracket to lower the tow ball height while pulling a caravan. I have done a few checks on the Web but not found anything specific. Any suggestions please?
cheers
Roger
Post #394947 1st Feb 2015 8:40pm
munch90
Guess he means a normal towbar drop plate
Post #394948 1st Feb 2015 8:41pm
Venomator
Something like the Dixon Bate Item Nr: TS/TH202091 shown > HERE
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #394950 1st Feb 2015 8:50pm
leeds
Roger bolt a tow ball onto the plate and measure the centre of the tow ball height from the ground it should be between 350 and 420 mm above the ground.
No need for guess work, just fit a tow ball and get your tape measure out.
As long as you have not got oversized tyres fitted and a 6" lift I would have assumed LR had done the measurements already but best to check.
Photo added
Brendan
Post #394952 1st Feb 2015 8:56pm
munch90
Even on the lowest holes they can be to high for a lot of trailers
the last thing you want is to be towing nose up as it makes it unstable
Post #394956 1st Feb 2015 9:03pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Is it not the same height as a standard tow bar?
Post #394958 1st Feb 2015 9:08pm
munch90
no i found it too high even for my big ifor williams trailer
standard tyres , no lift etc
Post #394962 1st Feb 2015 9:15pm
TJ101
Gen LR Adjustable towbar
Need for 4 different hight trailers, Ifor Williams and Brian James,
Would love a towstep bar BUT
I would not want to tow with the max weight a Defender can, with an adjustable on a tow step bar,, due to 3500 kgs of leverage etc,
There are some with lower stays that go back to the chassis California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #394969 1st Feb 2015 9:22pm
leeds
TAPE MEASURE TIME!
350 - 420mm is the height set out in EC Directive 94/20/EC
That is the height that caravan manufacturers will be working too.
Don't guess just measure!
Brendan
Post #394970 1st Feb 2015 9:22pm
Brillo
Folks
Thanks for your suggestions - will sort it when my new Landy arrives!
Post #395336 2nd Feb 2015 10:11pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Don't forget that the tow ball height is dependant on the load in the back of the car, it's pointless setting up with an empty boot and then setting off on holiday with a car full of people and luggage because then the suspension will be compressed making the ball lower and the caravan sit wrong. Also don't forget to allow for the nose weight of the trailer as that will compress the car too. Rhubarb and custard let fly with their secret weapon.
Post #395368 3rd Feb 2015 6:55am
nakatanenga
Germany
We name it "swan neck"
2 versions available:
up to 90mm lower
up to 160mm lower
Complete with all hardware and fully ECE approval.
http://nakatanenga-tours.de/shop/article_A...SHT-090%26 WANTED:
SII or SIII in max 1.5k
Post #395376 3rd Feb 2015 8:10am
Phib
1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I have a similar rear step on my 50th, we have tried many things because as you say it's too high to tow ( turns out in our case by about 1 inch!!)
We know this because we fitted twisted lowering and updated springs ( I know sacrilege !!) and it now is the perfect height for towing !!
Phib
Post #398044 11th Feb 2015 10:55pm
OP has OEM kit and that does have the lower stays that go back to the chassis - from the two pictures it looks like a very similar tow height could be achieved in relation to these stays with both setups?
Post #398090 12th Feb 2015 10:54am
leeds wrote:
TAPE MEASURE TIME!
Brendan
I found this to be helpful when considering the overall picture:
"The Directive gives us two height ranges – one for the tow vehicle and one for the caravan or trailer. However, if you look at the directive in detail it gives these height ranges in “Laden Condition”.
For the tow vehicle the ‘Laden Condition” may have been defined (by the manufacturer) as either fully laden (the maximum gross weight as shown in the vehicle handbook), or, conventionally laden (defined as 68.5kg per specified passenger seat and 6.5kg of luggage per specified passenger and located in the centre of the luggage storage area). Depending on the vehicle, there could be a height difference between these two loadings.
For the caravan or trailer, it is a little easier. “Laden condition” in this instance is when the caravan or trailer is loaded to its MTPLM (Maximum Technically Permitted Laden Mass) and the caravan or trailer chassis is adjusted using the jockey wheel so it is horizontal.
Just looking at the two height ranges, it is obvious that the regulations are designed so that in theory you always tow level or slightly ‘nose down’."
Source: http://caravanchronicles.com/guides/unders...ll-height/
Post #398093 12th Feb 2015 11:12am
