Home > Maintenance & Modifications > Lower the Tow Ball height on a Defender 90
Page 2 of 2 <12
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I don't need to measure to know the standard Land Rover tow bar on my 130 is very close to 50 cm off the ground. I'm guessing no one working at LR must ever have noticed that. Rolling Eyes
The one from Nakatanenga seems exactly what I'm after. Cool
Post #398096 12th Feb 2015 12:28pm
TJ101
Supacat wrote:
TJ101 wrote:
Would love a towstep bar BUT
I would not want to tow with the max weight a Defender can, with an adjustable on a tow step bar,, due to 3500 kgs of leverage etc,
There are some with lower stays that go back to the chassis
OP has OEM kit and that does have the lower stays that go back to the chassis - from the two pictures it looks like a very similar tow height could be achieved in relation to these stays with both setups?
You don't want to adjust the towball hight down on a tow step with either a drop plate or an adjustable slider like these
No support to the lower, I would not want, up to the max tow weight of a defender, swinging on a unstayed ball at the bottom of the plate
There is a picture somewhere that i can not find ! where someone has bolted a unstayed Dixon Bate adjustable slider to a tow step,, rather him than me !!!
Warpigs first effort !!!
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #398104 12th Feb 2015 12:49pm
TJ101 wrote:
Gen LR Adjustable towbar
Need for 4 different hight trailers, Ifor Williams and Brian James,
What's the difference between these two setups?
Both have the tow ball in line with the chassis stays and the mounting bolts for the tow bracket below the stays; albeit on the rear step bumper it is lower.
Post #398107 12th Feb 2015 1:02pm
leeds wrote:
TAPE MEASURE TIME!
350 - 420mm is the height set out in EC Directive 94/20/EC
That is the height that caravan manufacturers will be working too.
Don't guess just measure!
Brendan
Unladen - I don't know what the real world consequences of adding weight would be, only the theoretical one based on the spring specs:
Where are the measurements taken from to make these 90mm or 160mm lower - is it the lowest bolt hole on the backing plate?
Post #398166 12th Feb 2015 4:51pm
NickMc
i had a guy a few months ago towing an overloaded mini digger and trailer on one of the tdi disco brackets bodged on right angled plate on the bottom of the crossmember with no stays just two bolts Shocked
Post #399911 18th Feb 2015 1:36am
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
I'm after the plate in the blue defender where is it from??
i want to drop the ball using a plate but want a 6 hole version so it's attached with 4 bolts not 2
Post #451884 3rd Sep 2015 5:52pm
Page 2 of 2 <12
