Home > Td5 > Is there a permanent live and earth in the towing socket
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Can't find my tester so if anyone knows I'd appreciate it. 2005 TD5 90 CSW XS
Post #394926 1st Feb 2015 8:48pm
JAY BOY
Wales
This is the seven pin.
Post #394929 1st Feb 2015 8:55pm
JAY BOY
Wales
And 13 Pin
Post #394930 1st Feb 2015 8:57pm
Kent_keith
So no then as I have the 7 pin, ok thank you for that Thumbs Up 2005 TD5 90 CSW XS
Post #394935 1st Feb 2015 9:02pm
ericvv
The 7 pin towing socket is the 12N socket. No permanent live. But you can add a 12S socket, which does have a permanent live. If you do a search on here for 12S, you will find plenty of info about that. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #394940 1st Feb 2015 9:28pm
What would the purpose be for asking?
Post #394941 1st Feb 2015 9:33pm
Kent_keith
Eric
Does it have 8 pins then? 2005 TD5 90 CSW XS
Post #394960 1st Feb 2015 10:11pm
JAY BOY
Wales
No Keith its a different configuration. I will find one for you
Post #394961 1st Feb 2015 10:13pm
JAY BOY
Wales
There you go mate.
This one is for a caravan. in the old days you would have 2 plugs when towing. One for the trailer lights etc and one for the caravan electrics.
Post #394966 1st Feb 2015 10:17pm
Kent_keith
I'm going to fit a waterproof steel lockable yellow box on to my drive, attach a chain as a land anchor to the back of the defender also with an added security alarm that takes its supply from the towing socket with battery back up that will activate when it's unplugged or the wire is cut. 2005 TD5 90 CSW XS
Post #394972 1st Feb 2015 10:25pm
Kent_keith
JAY BOY wrote:
There you go mate.
Oh right I keep the 12n and add a 12s 2005 TD5 90 CSW XS
Post #394976 1st Feb 2015 10:28pm
JAY BOY
Wales
Keith
you could also add a charging circuit from a Ctek charger so you can keep your battery in tiptop condition. Thumbs Up
Post #394978 1st Feb 2015 10:31pm
JWL
What about a DIN plug and socket and if the worst comes to the worst it will pull out with no damage if you forget and go to drive away, it will still sound your alarm but is less prone to ripping plugs and sockets apart.
http://www.ebay.co.uk/itm/2-Pin-DIN-Hi-Fi-...1395432695
Post #394979 1st Feb 2015 10:32pm
JAY BOY
Wales
Can see the point if he's using the yellow box as a ground anchor. he will be going no where Shocked
Post #394982 1st Feb 2015 10:34pm
Kent_keith
JAY BOY wrote:
Keith
Then I would have to get 240v supply out there too, would be nice to have at a future date though. 2005 TD5 90 CSW XS
Post #394987 1st Feb 2015 10:42pm
