![]() | Home > Td5 > Oil in the Wiring Loom |
Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122 ![]() ![]() ![]() |
Hey team!
So - i've got rather a lot of oil in my 2004 TD5 110's ECU compartment, as yet no mis firing but I am thinking it would be better to fix this now rather than wait for a problem! Have done some reading and I reckon even for someone with my limited ability it's easy enough to do based on my not replacing the main wiring loom but just the injector harness. My questions if I may are as follows (sorry some of these are really basic/foolish): 1) What is the difference between the Paddocks Wiring Loom http://www.paddockspares.com/amr6103-injec...l?___SID=U and the Devon 4x4 One http://www.devon4x4.com/index.php?page=sho...;Itemid=14? The Devon one is £48 versus Paddocks £28, any thoughts on which to get? 2) I gather you need to seal the new Injector loom otherwise the same will simple happen again, people talk about an oil resistant sealant - what is good for this? Sorry it's a thick question but want to use the right one! Do you literally just coat the connector end with this? 3) My third foolish query is this - what solvent cleaner should i use on the main loom to help clear the oil out? Don't want to use the wrong one 4) If i put a new gasket on the rocker cover, do i need any past on it or anything like that? 5) What torque should the bolts on the rocker cover be done to? Thank very much team - really appreciate assistance! Anthony |
Q3....Any electrical cleaner as any residue will evaporate......I would probably go with the Electrolube one!
![]() http://www.amazon.co.uk/s/?ie=UTF8&key...httirrru_b If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
Very good guide here...
http://www.discovery2.co.uk/Injector_harness.html It's for a D2 but the same applies. The guy's guides are really very good. Think it answers more or less all your questions. Other than the one about the D4x4 one vs Paddocks... Tbh no idea. D4x4 are not quoting a part number but both are listed as OEM so I'd probably just get the paddocks one. |
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Even more choice here:
http://www.lrdirect.com/AMR6103-Wiring-Har...fi=AMR6103 |
Hey thanks!
Great guide and cheers for explaining the cleaner stuff. Oh dear god. Which to choose?!!!! |
Given the relatively low cost I'd go for the Genuine part and avoid the Britpart item for starters.
Good result. Thanks for getting back.
![]() Treat every day as if it is your last....one day you will be right!! |
Glad it went well. Hopefully now cured!
