Home > Maintenance & Modifications > Gas rams
landy andy
Gas rams
Need some help and info. I'm making a cage to go in the rear of my double cab load area. I'm planning to make a section that will swing upward, think of a old range rover clasic glass section, made from 25x25 angle iron with mesh over. What I would like is this section to easily operated with rams to lift and hold it up.
What rams do I require?
What size?
Where from?
Any another thoughts?
Thanks in advance
Andy
Post #394575 31st Jan 2015 8:44pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Andy
I have used these guys before for rams for a boardroom AV unit and university computer desks, their technical dept are really good helping you choose the correct Rams for your job Thumbs Up
http://www.sgs-engineering.com/gas-struts
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #394581 31st Jan 2015 8:51pm
JWL
There are plenty of companies that sell the struts and many offer a tailer made service where they can provide them to your specs, quick google brought up the likes of this company........ http://www.sgs-engineering.com/gas-struts
I'm too slow in typing Laughing
Post #394582 31st Jan 2015 8:53pm
I always use this place and have had excellent service from them.
http://www.strutsdirect.co.uk
Post #394583 31st Jan 2015 8:53pm
jomara
Laughing Laughing great minds eh 2014 110 2.2TDCi XS Station wagon
Post #394586 31st Jan 2015 8:55pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Hi Mate
try SGS engineering, they do them.
I would mark a point on your cage and a point on your lift up bit about 300mm apart and hold some string on each point while someone opens it, this will give you 300mm closed length and the length you need when its open.
Obviously there will be some messing about with dimensions and positions of your marks but you will be able to work out the length.
Second thing is weight , on the frame that opens , I would clamp a spring balance to where you think the strut will mount and see what force is needed to lift it.
Dead easy.....not Rolling Eyes
Thats how I have done it in the past Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #394590 31st Jan 2015 9:03pm
landy andy
Great thanks. Have not yet looked at links, but are they costly? Are there any rules thoughts on how to mount them? One part higher than other, always do X etc. or do you get rams and design around the rams?
Andy
Post #394591 31st Jan 2015 9:04pm
jomara
Hi Andy
We specified the ends, fixings, length stroke etc in conjunction with SGS technical guys, you just need to provide them with some information on sizes, weight if opening vertically, type of use etc.
If I remember correctly the total cost for the fixing plates ends and Rams came in around £70+VAT.
Post #394600 31st Jan 2015 9:17pm
