![]() | Home > Puma (Tdci) > Questions about Mantec Snorkel - Resolved |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
I'm looking at getting one of the plastic jobbies for my new Defender. Just got a few questions:
* Does the RAI just bolt and seal to the outside? * If so to seal the air intake system is there anything else you need to do to the ducting from the guard to the air filter? I've noticed there seems to be an open drain in the front of the filter box, is there anything else? * What's up in the turret section of this snorkel? Is it a precleaner or does it just bring air in from the rear of the turret? * Are all the metal bits galvanised, stainless or designed to rust? * Who is a good exporter to talk too? If I go to Mantec will they just point me at the Australian agent? I'll be importing it direct from UK (because I can do this and still come out ahead money wise). Safari are now saying they will have a unit for the TDCi by end of September, but I'm betting it will be priced above AU$600 (the Mantec is just below AU$600). To either one I then have to add at least AU$100 freight to get it to me. So if I can get one from the UK delivered for less than AU$400, makes sense ![]() 110 300Tdi ![]() LROCV ::: AULRO.com Last edited by dm_td5 on 18th Sep 2008 2:02pm. Edited 1 time in total |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Hi
A couple of threads to help you Mine http://www.defender2.net/forum/topic20-15.html AndrewS http://www.defender2.net/forum/topic106.html I sealed the air box, on the inner wing, as well as the pipe connection into the air filter housing !! Tim California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
No problem,,, if you look on Andrew's gallery,, https://www.defender2.net/gallery/thumbnails.php?album=26 you will find he did some better pictures ,,
![]() Hopefully the link works ![]() Main Brian James Trailer Dealer for South West UK |
Well I got my Mantec today, can't complain about the UK mail system - I know there are plenty who do - as it only took 6 days to get here. I ordered a Bearmach wheel carrier from an Australian stockist and it took over 2 weeks!
I recall seeing a comment that the fitting instructions are almost non-existent. Now that is an understatement ![]() Anyway I'm now armed with Andrew's gallery photo's all nicely printed for reference. Thanks Andrew for posting them up. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
