Home > Puma (Tdci) > Questions about Mantec Snorkel - Resolved
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I'm looking at getting one of the plastic jobbies for my new Defender. Just got a few questions:
* Does the RAI just bolt and seal to the outside?
* If so to seal the air intake system is there anything else you need to do to the ducting from the guard to the air filter? I've noticed there seems to be an open drain in the front of the filter box, is there anything else?
* What's up in the turret section of this snorkel? Is it a precleaner or does it just bring air in from the rear of the turret?
* Are all the metal bits galvanised, stainless or designed to rust?
* Who is a good exporter to talk too? If I go to Mantec will they just point me at the Australian agent?
I'll be importing it direct from UK (because I can do this and still come out ahead money wise). Safari are now saying they will have a unit for the TDCi by end of September, but I'm betting it will be priced above AU$600 (the Mantec is just below AU$600). To either one I then have to add at least AU$100 freight to get it to me. So if I can get one from the UK delivered for less than AU$400, makes sense Very Happy 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3126 10th Aug 2008 3:41am
TJ101
Hi
A couple of threads to help you
Mine http://www.defender2.net/forum/topic20-15.html
AndrewS http://www.defender2.net/forum/topic106.html
I sealed the air box, on the inner wing, as well as the pipe connection into the air filter housing !!
Tim California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3142 10th Aug 2008 12:15pm
dm_td5
Thanks Tim, I'd found Andrew's post already, but was looking for something like the pic's you've posted. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3145 10th Aug 2008 12:31pm
TJ101
No problem,,, if you look on Andrew's gallery,, https://www.defender2.net/gallery/thumbnails.php?album=26 you will find he did some better pictures ,, Smile
Hopefully the link works Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #3147 10th Aug 2008 12:37pm
dm_td5
Yes, works a treat, thanks again. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3154 10th Aug 2008 1:18pm
dm_td5
Well I got my Mantec today, can't complain about the UK mail system - I know there are plenty who do - as it only took 6 days to get here. I ordered a Bearmach wheel carrier from an Australian stockist and it took over 2 weeks!
I recall seeing a comment that the fitting instructions are almost non-existent. Now that is an understatement Sad
Anyway I'm now armed with Andrew's gallery photo's all nicely printed for reference. Thanks Andrew for posting them up. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3944 18th Sep 2008 12:50pm
