Home > Puma (Tdci) > Suspension and damping of the new Defender.
michel
Netherlands
How do you like your suspension of your new Defender, especialy the damping?
I find mine very hard and uncomfortable. It is a 90 CSW al with original dempers, springs and tires. Compare to my Defender 90 TD5 year 1999 which was much more softer.
Post #39423 31st Aug 2010 3:09pm
mse
Uprated suspension is why.
Put some weight in it and its really nice then...otherwise it is harsh Mike
Post #39443 31st Aug 2010 7:20pm
Glynparry25
Hi Michel,
I agree with you but I think it is down to 2 reasons why yours feels that way
1. Your Td5 has had 11 years to bed in and soften up.
2. LandRover really are terrible at matching springs and shocks to a vehicle.
Glyn Sheep
Post #39454 31st Aug 2010 8:34pm
michel
Netherlands
So far i have heard the new shocks are gas filled in stead of oil filled.
Also the part numbers are differend compare to my early DEFENDER TD5 from 09-1999.
Has anybody experince by changing the gas filled shocks for the older type which are oil filled.
I am wondering if the changed springs make the new Defender more hard are if it is caused by more rigid shocks.
Does make higher tires(for example 255-16-85) any differance?
Has anybady experince with the new BF Goodrich Muds KM2 in this size?
Best regard Michel.
Post #39512 1st Sep 2010 10:58am
MK
Yes, now they have gas charged shoxs. I would keep the springs and fit regulable shoxs (rancho or procomp). I noticed the difference.
Dindīt know LR does not know how to setup a suspension Shocked Puma 110" SW
Post #39515 1st Sep 2010 11:21am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i have been wondering about this as well, my wife describes the ride in the Puma as 'much more wiggerly....." Confused and it 'makes her bits wobble" Rolling Eyes
so........i think i will fit standard shocks as well.. did you just fit rear shocks or front as well? i don't ever carry much weight, it is normally the 2 of us and at best the weight of 3rd person or a weeks shopping!
ideally i would just like to fit new shocks on the back to reduce the rear bounce.
I would appreciate your view on this
cheers BM52
Post #39874 5th Sep 2010 4:15pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Shocked[/quote]
cheers[/quote]
This is great if the wife has a girls night and you offer to run them all home Whistle
Thats why i,ve put extra H/Ds on mine Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #39876 5th Sep 2010 4:25pm
MK
I can give an oppinion about a 110" setup. Anyway I find the front suspension is harder bacause of the design of front radius arms. My shoxs are set softer in the front and still find it rasher on the front compared to the rear.
For you to be on the safe side, I would get some regulable ones with upper and lower "stiffness" including " OE damping values. Not sure if you can get convinient prices for regulable shoxs (about $90/each).
On the other hand I do know "rough Country" shoxs are softer than OE and you get a nice ride for a few quid, so if you get the chance to compare your OE with oil filled ones, youīll have a good idea how much softer they are.
Hope it helps. Puma 110" SW
Post #39879 5th Sep 2010 4:41pm
bm52
going back to the 1st post by Michel - does anyone have a recommendation for making the ride smoother and more comfortable?
is it the springs and shocks?
or, will putting slightly softer shocks on make a difference?
if the answer is slightly softer shocks what make, can you get LR OE ones?
cheers BM52
Post #39907 5th Sep 2010 10:06pm
AndrewS
Check to see what colour code your springs are here http://members.shaw.ca/jbarge/springinfo.html you will be able to see what rate your spring is and work out what is needed from there. 130's have feeling's as well you know Smile
Post #39910 5th Sep 2010 10:26pm
iandup77
2008 Defender 110 Puma 2.4 SW Zambezi Silver
I have fitted Discovery coil springs infront(Blue Colour Code) Also fitted dual shocks front and back. Overall the vehicle is more stable in corners as well as no more top heavy. On rough roads you get a more smooth ride. On a quite night in Africa you can hear the sound of rusting Land Cruisers
Post #39945 6th Sep 2010 11:32am
fekete
I also have HD Discovery coil springs all round with bilstein shocks and this has stop the roll and improved the smoothness on the road Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #39946 6th Sep 2010 11:46am
harveyg77
JE Eng have recommended I fit Koni gas & adjustable dampers and their upgraded roll-bars to improve ride.
How do you tell what colour code your springs are, mine appear black, with 'no' noticeable colours, bar the front left which has 1" yellow marks every inch or so!
Thanks Harvey
Post #39960 6th Sep 2010 1:35pm
AndrewS
Every spring from Land Rover is colour coded. If you clean the spring you should see one or two colours painted on the coils, usually a number of the coils have paint on them. Land Rover employ a blind man on a galloping horse to paint the springs, he usually paints them on a foggy night so dont expect to see clearly marked springs Thumbs Up
I just ordered a set of OME Nitrocharger sport shocks for the 130.
Post #39962 6th Sep 2010 2:01pm
bm52
been thinking - a dangerous trait i know but if we kept the LR dampers as standard and fitted light or medium Terrafirma rear springs i assume that would help. LR Dealer told me mine was fitted in the factory with HD springs.
i have no idea how to set up suspension so any advice welcome.
would it be sensible to keep the front standard fit and just repalce the rear or should you replace everything as a set? BM52
Post #40106 7th Sep 2010 6:43pm
