Home > Puma (Tdci) > Suspension and damping of the new Defender.
Page 2 of 2 <12
AndrewS
Do to the front as you would do to the rear Thumbs Up 130's have feeling's as well you know Smile
Post #40113 7th Sep 2010 7:53pm
MK
Check the colour stripes on your springs. If they are HD then they are of course stiffer. You can go to LR std springs or even softer OME752.
LR gas filled shoxs are by far stiffer than std oil filled (Armstrong), Rough Country RS9000 (both cheap) and OME (more expensive).
For the front there are both std and HD springs. I do not think you just got HD on the rear.
MK Puma 110" SW
Post #40120 7th Sep 2010 8:05pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi
i can see the colours on 3 of the springs.
o/s rear is Yellow Green White
o/s front is White Green Red
n/s front is Yellow Green Red
AndrewS - any ideas on their rating, i can't see the codes on chart?
i have also searched the web, but no results Sad BM52
Post #40201 8th Sep 2010 6:36pm
harveyg77
I ned to check mine again as the fronts are covored in yellow marks and I could not see anythign on the rears Sad
Post #40221 9th Sep 2010 7:11am
MK
Road spring data
Road spring Part number Colour code
90 2 seat utility (2400 Kg)
Front - Driver's side REB500200 Red/green/white
Front - Passenger side REB500220 Red/green/orange
Rear - Driver's side NRC 9448 Blue/red
Rear - Passenger side NRC 9449 Yellow/white
90 2 seat utility (2550 Kg)
Rear - Driver's side RKB101230 Green/yellow/red
Rear - Passenger side RKB101240 Green/yellow/white
90 4 seat station wagon (2400 Kg)
Rear - Driver's side RKB500290 Red/green/green
Rear - Passenger side RKB500280 Red/green/red
90 4 seat station wagon (2550 Kg)
Rear - Driver's side RKB500270 White/green/pink
Rear - Passenger side RKB500310 White/green/purple
LHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Driver's side NRC 8044 White/white
Front - Passenger side NRC 8045 Yellow/yellow
Rear - Both sides RKB101111 Purple/brown
RHD 110 2 seat utility, 5 seat station wagon and 5 seat crew cab (3050 Kg)
Front - Both sides NRC 8045 Yellow/yellow
LHD 110 7 seat station wagon (3050 Kg)
Rear - Both sides RKB500300 White/green/green
RHD 110 7 seat station wagon (3050 Kg)
110 heavy duty and all 130 (3500Kg)
Front - Driver's side NRC 9448 Blue/red
Front - Passenger side NRC 9449 Yellow/white
Rear - Both sides 78 of 1212 RKB101111 Purple/brown Puma 110" SW
Post #40222 9th Sep 2010 7:43am
Page 2 of 2 <12
