Home > Puma (Tdci) > Puma 2.4 aircon |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
As silly as this sounds... Have you tried it with different blower positions? Normally you have to have the blower in the first notch before it will activate the fan and air con
29th Jan 2015 10:11pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Not sure about the Puma but A/C rad fan on Td5 doesn't cut in below 28degrees C, your system probably needs gassing. 2005 Td5 90 XS
Steve |
29th Jan 2015 10:12pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
I know it gets cold, not modorn car level, but even in hot weather it makes it quite comfy.
Mine's a 110 so plenty of air to cool. If you can't get it to cool, you are wright, there's somthing wrong with it. |
29th Jan 2015 10:14pm |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 444 |
Yes I had it on number 1 as I thought that a good test would be to see that the window steamed up briefly before clearing as this is what it says in the manual. It didn't
I don't suppose there is a workshop manual available........... Dave |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10380 |
As LikeOMG says.
I'm surprised it won't work, my td5 aircon works a treat, which I wasn't expecting. Though I'll never use it in this country! |
29th Jan 2015 10:15pm |
I know what you mean about the weather.
I did think to myself that it was slightly odd behaviour sat in the drive trying to get my aircon working when it was about 5 degrees outside. I have a nanocom and plugged that in in the hope that I could manually activate the AC clutch and and AC fan but doesn't have the ability. Dave |
29th Jan 2015 10:19pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
On a puma, when you switch the air con on the fan speed spins at setting one even in the 0 position, if it's cold outside you won't be able to test it for temperature, I always leave mine switched on either hot and cold setting, if your windows are steamed up on a wet say the air on dries the air in no time, air conditioning doesn't just mean cold!
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
29th Jan 2015 10:23pm |
Yes,
Fully aware of that, says so in the manual......... The windows haven't steamed up yet mind, as it is lacking the small lakes in each footwell that I have become accustomed to in Land Rovers i've previously owned. What I was getting at is that the windows steam up because the aircon is switched on and then clear, but it didn't do this. Dave |
29th Jan 2015 10:29pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Probably just needs a gassing.
In a Puma even if the inside fans are on '0', they come on a speed '1' when you press the A/C button (does in mine anyway). I believe this happens whether the system is gassed or not. When you press the A/C button you should hear the engine rpm drop slightly as the compressor clutch engages. If the gas is low, the compressor is not activated and the engine rpm will not drop. My 07 Puma has stopped working over the last few weeks and suspect it needs gassing as the compressor doesn't start. I don't think it's ever been re-gassed. I have heard of compressor clutches that have seized due to not being used, but not sure if that's myth. When you get a re-gas, they will put dye in the gas and check for leaks. If it leaks then by law they have to remove all the gas and the leak will require fixing. Hopefully, it's just normal release that happens over time and just needs refilling. As for temperature control, that's only half the job of A/C. As the name suggest it conditions the air which includes the removal of moisture which is why you get the puddle of water underneath. Great this time of year to stop the windows steaming up. This is why on a lot of modern cars with Climate Control, you have the option to disable the A/C instead of turning it on. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
29th Jan 2015 10:31pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5684 |
As above, sounds like it needs re gassing. Took mine to Kwick fit. As they had a deal on £50
Andy |
29th Jan 2015 10:44pm |
Thats brilliant information thanks.
Where did you get your information from? Is there a manual somewhere? I will try and find a local aircon specialist to see if it can get checked out. Frustrating that the nanocom what buzz the aircon clutch and the fan like it does in the Td5 Disco |
29th Jan 2015 10:45pm |
Just had a look, ATS have got a special offer on at the moment. £29.99
Dave |
29th Jan 2015 11:00pm |
wmca Member Since: 15 May 2013 Location: Brisbane Posts: 26 |
Hi, the northern hemisphere I would think is ‘kin cold currently and difficult to test for cold air con, In AU we do rely heavily on air con and although not the best system made it makes it a little more cnfortable in 30c+ temps here.
If your Puma is from 2007 to 2010 there are two things to consider, the thermistor behind dash or clutch failure, rarely is there a gas problem. When air con button used in any fan speed setting it will activate the air con above providing the outside temp is above 5c. If air con is working and provided the selection switch in in correct position there should be no fogging off any front windows. Hope this helps and good luck. WMcA Brisbane Australia Defender 2.4 Puma 2009 “Airbags! The other vehicle is my crumple zone!" |
29th Jan 2015 11:15pm |
Maybe it's to do with the variances in atmospheric pressure as it's quite normal in the UK for A/C to require the gas topping up in any vehicle after a few years. There never seems to be a pattern though, sometimes a 15 year old car will still be working fine but a 4 year old car will be empty.
The performance of the A/C starts to drop as the gas levels get lower until the pressure switches disable the compressor. Land Rover and Jaguar offer a re-gas and service as part of a normal routine service. Not sure if they do on a Defender but they certainly offer it on a the Range Rovers as it was done on the Evoque at last service. It was also done every 2 years on both Jaguars I owned. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
29th Jan 2015 11:27pm |
