Home > Puma (Tdci) > Cleaning the engine bay
Page 2 of 2 <12
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I use Autoglym machine cleaner a long handled brush and a gentle rinse from a hose before dressing with ACF50 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #392857 26th Jan 2015 11:03pm
martinfiattech
I jet wash engines every day, never had a problem. Unless it gets in side a dizzy cap / H.T lead. Big Cry
Have the engine warm and running, avoid electrics or cover if unsure .
Spray with de greaser, allow to work or scrub in. Power washer on low pressure and hot. Keep a reasonable distance from power unit and all will be well.
Afterwards I blow off all looms and electrical connections with an air line, take vehicle for a run just to make sure all is well.
So far so good.
However I would`ent do it every time I wash the car, mine gets done a couple of times a year, in fact it got it`s chassis and every thing else steam cleaned tonight after work. Keeps the road salt at bay.
Now I just have to re grease my brake pipes !! Excuse the spelling I`am better with spanners and wires.
Post #392877 27th Jan 2015 12:00am
gilarion
If you use a good engine degreaser, I swear by GUNK, follow the instructions on the can and apply liberally with a brush to the engine. Then just rinse off with a garden hose. There is no need to use a pressure washer if you use a degreaser.
Post #392965 27th Jan 2015 12:42pm
Alex1976
I washed my Jag engine bay (same Ford 2.2 diesel engine) just with some fairy liquid and a brush and rinsed with hose trying to be careful. I still ended up having a battery light on my dash for weeks afterwards until I finally traced a fault to a blown wire from the battery to the alternator which I presume failed because of the washing - too much of a coincidence otherwise.
I would be very nervous about washing the engine bay again.
My 300tdi however is regularly sprayed with degreaser and then jet washed and never even a hiccup of a problem. Smile
Post #393024 27th Jan 2015 5:20pm
jimbob7
I've jet washed engine bays in all my cars,petrol or diesel. Pov.spec,ftw. 2006, 110,TD5.
Post #393027 27th Jan 2015 5:30pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I use either Autoglym Engine & Machine Cleaner or Bilt Hamber's Surfex HD, worked in with a brush, followed by rinsing with water from an open hose pipe.
http://www.autoglym.com/products/products/...ne-cleaner
or:
http://www.bilthamber.com/cleaning-and-degreasing/surfex-hd
If you like things shiny, a spray with Autoglym Vinyl & Rubber Care afterwards, and whilst it's still damp, will keep you very happy
http://www.autoglym.com/products/products/vinyl-and-rubber-care
Remember, as Old Scrotum the wrinkled retainer, in 'Sir Henry at Rawlinson End' (look it up) once said: "Shiny always looks dandy."
Incidentally, I believe washing up liquid contains salt, amongst other things.
Post #393028 27th Jan 2015 5:33pm
Washing up liquid is a serious danger to paintwork, and is designed to leave an attractive sparkling salt residue on plates which you don't want on your pride and joy! I never let washing up liquid near any of mine.
Post #393030 27th Jan 2015 5:38pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
It is fine but just be sensible.
If you can turn down the pressure of the lance then do so.
Keep back and don't force the water jet into the electrics, any sensitive looking areas wrap a shopping bag or freezer bag around it.
Lets face it you drive through pouring rain, puddles and in the case of Defenders rivers without a thought for water in the engine bay.
The secret is to let the cleaning product do the work and the power wash is just a rinse off.
I use Meguiars Super Degreaser mixed 1:4
Spray it liberally and from as many directions as you can, have the engine warm but not hot or it just all dries up.
A long handled 2" paint brush to agitate the cleaner. I have electrical tape wrapped over the metal part to prevent any scratches or damage being inflicted.
Let it soak. I usually do the engine bay with the degreaser, close the bonnet, then snow foam the exterior and rinse before returning to the engine bay.
Turn down the lance.
Keep well back, you are only rinsing not using the pressure washer to clean the degreaser has done that bit.
If you want bling - I apply Autoglym Instant tyre dressing, just spray it all over again from multiple directions and liberally when the engine is still damp then shut the bonnet and continue cleaning the rest of the exterior.
Once the rest of the motor has been done just pop up the bonnet and using an older microfibre dab away any excess that has pooled or puddled.
Finished
Post #393065 27th Jan 2015 8:04pm
HardCharger
Thanks for the feedback and tips.
If there are any more, feel free to chime in! The more the merrier.
I'm actually concerned about the corrosive effects of the volcanic ash on the engine and electronics.
Post #393196 28th Jan 2015 3:01am
Flyingfocrs
The biggest issue with volcanic ash dust is not so much the corrosion but the abrasive properties.
Once it gets into moving parts if it has a high silica content then it will act just like emery cloth and wear at moving parts.
blowing it out with compressed air on sensitive parts creates it's own hazards, eye and respiratory protection being the most obvious ones as lets face it you don't want to be ingesting the stuff either.
Washing it out with water creates the risk of if not done sufficiently then the ash can solidify like cement.
i would say the best all round option would be to don sufficient PPE and get an air line into the alternator as a minimum then clean the engine bay as described above then ideally get the vehicle up in the air and give it a full clean underneath. Even repeating the process a couple of times to ensure it is fully washed down in all nooks and crannies.
Reapply any anti corrosive protection you have used previously or apply it if not done before.
Fluids and filter change.
Even with that i would still anticipate you may see a premature alternator or wheel bearing failure, of course this depends as well on the level of exposure to the ash and the type as well. Higher the silica content the greater the abrasion.
Post #393255 28th Jan 2015 11:43am
CatherineF wrote:
I know someone quite well who does a lot of professional detailing.
They suggested I should use an engine cleaner, detailing brush and just a hose not a pressure washer.
+1 - let the products do the hard work of cleaning and lifting the dirt and then just a gentle rinse does the job.
303 Aerospace Protectant seems highly thought of on several detailing forums:
Post #393306 28th Jan 2015 2:14pm
HardCharger
Thanks for the additional tips, Flyingfocrs!
Will definitely do these. I will still have one more run so I shall be doing the intensive cleaning after that.
For the meantime though, just blasted the engine bay and bonnet with compressed air and it looks almost totally clean. Had I seen you post tester afternoon, I would've also sprayed the alternator as you suggested. Also sprayed out the air filter, and now the truck pulls nicely again.
That stuff is like fine powder and gets everywhere! I may have to spring for total detailing service so that we get all the little nooks and crannies! Might have to pull down the AC for a wash too.
Post #393522 29th Jan 2015 3:04am
Page 2 of 2 <12
