Home > Puma (Tdci) > I think it's sorted now, but...
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Just wondered if I could ask a few questions, to stop me getting paranoid...
Got Big Black back today after it's been playing funny Censored , and I think it's sorted, however, after a long drive I can't work out if it's fully sorted...
SO! Anyone with a perfect fully working Puma Defender...
- Are their any clunks (quiet or loud) at all when changing gear or taking up drive, especially in higher gears at higher speed?
- Any clunks when slowly taking up drive when 'shunting' around, i.e. just moving it slowly on the clutch in first and reverse
- Does your clutch bite near the top, bottom, and is it 'sudden' in taking up drive?
After having it for more than a year you'd think I'd know where the clutch bites, but after being without it for a couple of weeks and putting just over 1500 miles on the Freelander courtesy cars I've had (annoyingly I've been without the Defender on two of the busiest weekends I've had all year) I've sort of forgotten how it drove Confused
Can't work out if I'm being paranoid or not!
Cheers!
Post #39180 26th Aug 2010 10:04pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Prior to having the clutch replaced my Puma was quite clunky. I had to concentrate on getting a smooth change. The replacement clutch solved the problem. However, I recently had the ECU upgrade (V2 I think) and that has transformed the gearchange.
I would say the change is as smooth as my wife's FL2 auto. Also, starting from rest in either 1st or reverse is just a matter of letting in the clutch without any initial acceleration.
The clutch bites progressively and I am not aware of it biting at any particular point. 2nd gear starts are now possible if it's only slightly downhill of barely moving in traffic. The ECU upgrade made these improvements.
There are no clunks and I don't think any could be induced even with a clumsy gearchange.
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #39182 26th Aug 2010 11:33pm
MK
I think I´m entitled to speak about transmission clunks. Unlikely to be the gearbox. Problems exist between the TC input shaft all the way to diffs.
1) lifted front and unlock, (better without front shaft) turn with your hand the output shaft. You should not get more 1/16ish of a turn
2) front and rear diffs´flanges: like 1/8ish of free turn
3) Make sure both propshafts are not "in fase or aligned between yokes". They must be at ca. 30º.
4) Also check UJ´s. Be generous in grease. I do it every 3-5kkm. Cost a penny.
I was for months and after several TC´s trying to figure out the problem. My front propshaft had the wrong setup from factory..... Shocked
Now, I have no clunk (maybe a femto clunk).
NB: There is also the thing with engine speed sensor attached to the clutch hydraulics. Can not tell much about it. Puma 110" SW
Post #39183 26th Aug 2010 11:59pm
discocuzzy
Mine cluncks in every gear unless i change very smoothly Big Cry You cannot teach stupid people to do clever things
Post #39184 27th Aug 2010 12:24am
roel
I thought a Defender has to clunck, if it doesn't clunck it's broken. Whistle Roel
2003 90 Td5 (2009-now)
Post #39191 27th Aug 2010 6:56am
Naks
Re: I think it's sorted now, but...
Dunno about that, but here goes:
Most of the drivetrain clunk occurs at low speeds and gears 2-4.
nope. there should be a 'clack' when you release the clutch in neutral though.
nope, it's gradual.
Post #39197 27th Aug 2010 7:26am
bob neville
None and has never had any.
About an 1" from the floor and gradual.
None of this applies to 2nd gear as 99.99999% of the time I can't engage it !
Bob
Post #39208 27th Aug 2010 11:21am
Naks
bob neville wrote:
None of this applies to 2nd gear as 99.99999% of the time I can't engage it !Bob
Shocked
Post #39209 27th Aug 2010 11:25am
warren
Cheers for all the replies guys! Thumbs Up I owe you all a beer!
Well, seems mine is a bit more sorted than it was before, but still not right...
The clutch bites quite near the top, and I still get the occasional clunk when taking up drive after changing gear, but don't know whether it's bad enough to send it back or just need to concentrate a bit more on getting a smooth gear change, or if I'm just being overly picky. Having said that I can't ever remember it being an issue when it was new, or when I test drove one. Then again that is quite a while back now...
Other than that it seems fine. I think.
I get the clack when releasing the clutch in neutral, was never sure if that was anything serious or not, so thats a relief!
I'll be jacking it up soon (using jacks and axle stands... not expensive lift kits....) as I'm going to waxoyl it, so I'll give MK's advice a bash!
Cheers again! Thumbs Up
Post #39216 27th Aug 2010 1:11pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Check out the 'A' frame balljoint bush. Ball joint can appear to be ok upon inspection but sometimes the bush is not centred correctly. Fixed my problem with clunks. No need to replace bush if vehicle is reasonably new.
Post #39237 27th Aug 2010 6:19pm
warren
Well I had a look underneath this morning whilst someone was inside taking up drive, and found the source of the clunk!
The prop turns almost a quarter of the way around before the Landy moves, then clunk and your off!
Post #39266 28th Aug 2010 12:31pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Mines the same, should we be worried Shocked Cogito ergo sum
Post #39274 28th Aug 2010 5:06pm
MK
check if it is the Tbox or any diff. Puma 110" SW
Post #39277 28th Aug 2010 6:54pm
CapeLandy
South Africa
1/4 turn is huge Shocked mine from new was only about 15mm or so
Post #39304 30th Aug 2010 5:27am
MK
Is that slack from the Tbox or diff? Puma 110" SW
Post #39345 30th Aug 2010 1:47pm
