Home > Puma (Tdci) > Puma EGR fault |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2650 |
James, you can come check on mine when you're around GB Maybe it is a fresh air intake, to allow people to blank off the EGR without the MIL coming on? |
27th Aug 2010 7:26am |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
I had my EGR replaced recently too - just checked mine - it's the same as Cape Landy's one in his photos - with the hole. I'm keen to find out if this is indeed a new modified part, because my LR dealer said they were the same - not that they aren't usually wrong! I can't remember what the old one looked like either.
On the good news front - my Puma has been trouble free for several months now, which, if anyone recalls my earlier posts - is very good news. I'm enjoying it now. |
30th Sep 2010 11:32pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Mine's also been very good.
I saw on my printout that they did also another software update at the time of my EGR valve. That might also explain while there was such a difference when she came back. Now I am scraping together all the overtime I can to afford the extended warenty although the exclusions are a bit scary considering it's a puma. |
1st Oct 2010 5:35am |
Well - my new EGR took all of a few months to again raise it's ugly head - engine surges on/off throttle. Still waiting to discover the best blanking solution - we have 3 it seems, Robofarmer, Bell and the German fellow. I can't believe these EGR valves are so prone to causing issues.
Add to this - oil weeping from new transfer case flange seal. Is it the LR mechanics - or these vehicles? The unfortunate pattern of getting at the most 8 weeks without failure is alive and well. |
3rd Oct 2010 8:24pm |
Yes, that is the symptom mine had - sounded a bit like a cricket with a silencer chirping near the fuel rail and revs were a little eratic and mostly ony when cold - gets much worse over a few weeks so that when you shut down the engine when cold it sounds like loose spanners clanging about |
7th Oct 2010 11:52am |
