Home > Technical > TD5 or 50th Annivesary speedo question
Culminator
Can someone please confirm what other Defenders share the 50th speedo? I need to know where the speedo needle gets its signal from as mine isnt working.
Thanks!
Post #391480 22nd Jan 2015 2:43pm
g-mack
Post 2002 td5 (digi odo)take it from a transducer in the tranny box
Not sure bout 50th though My 109 thread
my youtube channel
Post #391492 22nd Jan 2015 3:47pm
The 50th Speedo is not the same as the TD5, it is unique to the 50th
Post #391498 22nd Jan 2015 4:39pm
Culminator
OK great, it's unique then, thanks for clarifying. Before I take it out and send it away, I want to be sure that the problem is not to do with the electrical feed or sensor pick up that moves the needle. When I switch the ignition on, the needle twitches, so it's getting an ititial feed and i'm thinking the actual guage may therefore be OK and that's it's more to do with a pick up sensor. I think I heard somewhere that they have a sensor near the rear wheel????
Thanks again!
Post #391501 22nd Jan 2015 4:51pm
Martin
Site Admin
I think the speedo sensor is the same as a Td5 though, YBE100530.
The Td5 one is a development of the 50th/NAS one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #391524 22nd Jan 2015 6:27pm
Romadog
Martin is correct. Thumbs Up
Post #391526 22nd Jan 2015 6:36pm
Culminator
So is the sensor located near the gearbox or near a rear wheel? Could a blown fuse cause a failure like this and does anyone have a fuse layout or wiring diagram?
Thanks!
Post #391619 22nd Jan 2015 10:17pm
Martin
Site Admin
It's on the side of the transfer box behind the handbrake drum.
I have got a wiring diagram but not on my phone Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #391622 22nd Jan 2015 10:21pm
g-mack
Don't think its fused on its own, 3 wires straight from transducer to speedo harness plug My 109 thread
my youtube channel
Post #391631 22nd Jan 2015 10:41pm
Martin
Site Admin
Fuse 18, but this would have also taken out the brake lights, reverse light and front wiper.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #391632 22nd Jan 2015 10:42pm
Culminator
That's fab guys. So, without further investigating as its too bloody cold, when I bought the car and test drove it, the speedo worked but when I picked it up, the front wiper didn't work and neither did the speedo. The fuse for the wiper has blown, I know that as I've already checked but not replaced it yet. I'd be very happy if this has also caused the speedo to stop working and wondered if they were connected in some way the other night. Thumbs Up
Post #391639 22nd Jan 2015 10:58pm
Martin
Site Admin
If that is the case you don't have brake lights or reverse lights either, so change the fuse before you go out on the road Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #391641 22nd Jan 2015 11:03pm
Culminator
Cheers Martin, I hadn't realised that but thankfully not driven it since I picked it up.
Post #391647 22nd Jan 2015 11:15pm
Culminator
Update!
So, my speedo failure was indeed down to a blown fuse! Thumbs Up So, if anyone else has a failed speedo on a 50th, check if your wipers have also failed and if they have, it's the blue 15 amp fuse that's gone. Thanks forum Mr. Green
Post #392083 24th Jan 2015 1:09pm
mk1collector
Check the wiper boxes and see if they need un seizing because if the motor is labouring that sometimes blows the fuse.
Post #392107 24th Jan 2015 3:37pm
