eutek
Hi all,
I swapped out an LED replacement for the interior dome light, as the light is a bit too dazzling, however it appears that in doing so I must've broken something - as the lamp no longer works!
Perhaps I should've switched the light off first?
I pulled the LED out and popped a bulb in, however it didn't work. Stayed dark... not only that but the rear dome light is out now as well - and I hadn't touched that.
This is a new low point for me from a technical point of view, I figured that even I could be trusted to swap a few bulbs.
Had a look in the workshop manual, don't see a fuse for the interior lights - is there one?
Anyone know what I should check?
19th Jan 2015 5:28pm |
eutek
19th Jan 2015 5:32pm |
