Home > Technical > No interior lights
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
No interior lights
Hi all,
I swapped out an LED replacement for the interior dome light, as the light is a bit too dazzling, however it appears that in doing so I must've broken something - as the lamp no longer works!
Perhaps I should've switched the light off first?
I pulled the LED out and popped a bulb in, however it didn't work. Stayed dark... not only that but the rear dome light is out now as well - and I hadn't touched that.
This is a new low point for me from a technical point of view, I figured that even I could be trusted to swap a few bulbs. Embarassed Laughing
Had a look in the workshop manual, don't see a fuse for the interior lights - is there one?
Anyone know what I should check? Sad
Post #390252 19th Jan 2015 5:28pm
eutek
Doh - think I just found the answer, in this thread http://www.defender2.net/forum/topic5835.html.
I'll venture outside tomorrow to sort it - too cold and dark now!
Post #390254 19th Jan 2015 5:32pm
