Home > Tdi > R380 knocking/ticking.
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Hi all, after a little help. My new to me defender came with a gearbox problem. It has sat for three years and the previous owner thought it was the thrust bearing but I'm not sure. So it has a constant knock while running. It increases with revs and does it in natural and every gearbox except 4th and when clutch is pressed. Other than that it runs smoothly and changes gear nicely.
Any help to diagnose it would be great.
Chris.
Post #388554 14th Jan 2015 10:24pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
If it's not in 4th I would suspect lay shaft bearing. Rhubarb and custard let fly with their secret weapon.
Post #388632 15th Jan 2015 7:39am
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Knocking usually means broken teeth.
See whats in the oil, will either be teeth or like lambert says bits of bearing. Big Cry 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #389999 18th Jan 2015 9:52pm
