Home > Puma (Tdci) > New owner, unhappy owner |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Dan zal't wel in orde komen. Die zijn top!
12th Jan 2015 11:31pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Thats not good news.
What year and engine do you have please. |
14th Jan 2015 11:32pm |
nielsds Member Since: 10 Jan 2015 Location: Antwerp Posts: 14 |
2010 2.4 Engine, 90.000 km's
14th Jan 2015 11:53pm |
Col Member Since: 16 Jul 2014 Location: Somerset Posts: 7 |
Just a thought, some 2.4 tdci engines had a problem with 'PCJ' 'piston cooling jets' which caused bore damage then high oil consumption and high internal engine pressure.
From what I have read, it should have been fixed before your 2010. Further information along with affected engine numbers is available on other posts. Try a search for 'pcj' if you think may help. |
15th Jan 2015 12:22pm |
Jay Member Since: 23 Apr 2012 Location: Veneto Posts: 27 |
This is the service bulletin
Service Bulletins SSM38792 Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise. Title: 2.4 Puma Engine Knock Noise. Type: LD - Defender - All Years - Special Service Messages - Engine Name / Part No: SSM38792 Info Type: Service Bulletins Version No: 1 Date Uploaded: 21 Jul 2008 Models: LD - Defender Title: 2.4 Puma Engine Knock Noise. Last Modified: 21-JUL-2008 09:44 Category: Engine Symptom: 497000 Engine Noise Content Issue: Heavy audible knocking heard on start up. Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur. Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used. This condition will not occur on vehicles post assured Vin# 9A767162. Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed. check VIN, but mine is out, and was made in 2009 November (AA789018) Jay |
15th Jan 2015 1:06pm |
It ends in AA789872, so that can't be it ?
thx! |
15th Jan 2015 5:06pm |
Maybe the engine isn't "bad".
There could be a leak on the (i think gasket ?) of the injectors, true this way there can leak oil directly on to the pistons. (i hope i translated it all correctly) Whats your opinion ? |
21st Jan 2015 2:40pm |
What did Alain or Eric say it is?
21st Jan 2015 4:53pm |
The maybe comes from Alain, we will test it next week. Lets hope..
22nd Jan 2015 5:27pm |
Keep us posted and say hi next time you see him
22nd Jan 2015 7:10pm |
The verdict:
There was a leak on the injectors, the copper (or brass ?, i forgot) plate thats seals them was leaking. Surprised there was no O ring... 2 injectors where replaced, the other 2 where cleaned. It will be €1000+ buts its still better dan a new engine ! Thx for the help ! |
7th Feb 2015 6:01pm |
