Home > Puma (Tdci) > New owner, unhappy owner
Page 2 of 2 <12
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Dan zal't wel in orde komen. Die zijn top!
Post #387892 12th Jan 2015 11:31pm
nielsds
Belgium
The car is back from service. Very solid car, BUT the engine is bad Sad, hes blows blue smoke, and when the oil filler cab is of he is blowing smoke to... so he really uses oil...
To know what is coming, what will a rebuild cots ? a used engine, or a rebuild swap ? any suppliers ?
thx
Post #388596 14th Jan 2015 11:28pm
JAY BOY
Wales
Thats not good news.
What year and engine do you have please.
Post #388598 14th Jan 2015 11:32pm
nielsds
Belgium
2010 2.4 Engine, 90.000 km's
Post #388607 14th Jan 2015 11:53pm
Col
United Kingdom 2003 Defender 90 Td5 PU Oslo Blue
Just a thought, some 2.4 tdci engines had a problem with 'PCJ' 'piston cooling jets' which caused bore damage then high oil consumption and high internal engine pressure.
From what I have read, it should have been fixed before your 2010.
Further information along with affected engine numbers is available on other posts.
Try a search for 'pcj' if you think may help.
Post #388683 15th Jan 2015 12:22pm
Jay
Italy 2010 Defender 110 Puma 2.4 SW Stornoway Grey
This is the service bulletin
Service Bulletins SSM38792
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
check VIN, but mine is out, and was made in 2009 November (AA789018) Jay
Post #388696 15th Jan 2015 1:06pm
nielsds
Belgium
It ends in AA789872, so that can't be it ?
thx!
Post #388756 15th Jan 2015 5:06pm
nielsds
Belgium
Maybe the engine isn't "bad".
There could be a leak on the (i think gasket ?) of the injectors, true this way there can leak oil directly on to the pistons.
(i hope i translated it all correctly)
Whats your opinion ?
Post #391040 21st Jan 2015 2:40pm
zone30
What did Alain or Eric say it is?
Post #391069 21st Jan 2015 4:53pm
nielsds
Belgium
The maybe comes from Alain, we will test it next week. Lets hope..
Post #391496 22nd Jan 2015 5:27pm
zone30
Keep us posted and say hi next time you see him Wink
Post #391519 22nd Jan 2015 7:10pm
nielsds
Belgium
The verdict:
There was a leak on the injectors, the copper (or brass ?, i forgot) plate thats seals them was leaking.
Surprised there was no O ring... 2 injectors where replaced, the other 2 where cleaned.
It will be €1000+ buts its still better dan a new engine !
Thx for the help !
Post #396705 7th Feb 2015 6:01pm
Page 2 of 2 <12
