Home > Maintenance & Modifications > Heated Washer Jets
Page 2 of 3 <123>
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I wondered that myself. http://defender90xs.blogspot.co.uk/
Post #388288 14th Jan 2015 7:14am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I am hoping most are going to another distributor however I am sure I can find a few sets at a reasonable price.
Post #388507 14th Jan 2015 7:56pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I've heard they really need to be sub-£100 to be reasonable value......... Whistle 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #390701 20th Jan 2015 7:35pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Consumerize, thanks for the write up. Looks like a sensible, low cost mod. Thumbs Up
I've just ordered the parts and will be fitting the gear as soon as it arrives.
cheers
LRmud
Post #390767 20th Jan 2015 9:01pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Glad it helps.
One thing you need to do, if you have opted for the thermostatic switch mentioned is set the switch for Heating, rather than Cooling, so it clicks on when its at low temp, rather than high temp. by default its set to Cooling. simple change in the settings, if you can interpret the loosely translated Chinese to English instructions.
Post #391045 21st Jan 2015 2:03pm
PaulMc
consumerize wrote:
...if you can interpret the loosely translated Chinese to English instructions.
Known as 'Chinglish' or 'Engrish'
Have a look at some of the pictures in these Google image searches Laughing
Chinglish images
Engrish images
. Paul.
Post #391073 21st Jan 2015 4:10pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I picked up a brand new Heatshot (mid-summer) for around £100, the dealer said he couldn't shift them during the summer so he dropped price and went back up during winter months where the demand was higher, bought about 2yrs ago, great mod Thumbs Up even though, if my washer mix is weak the nozzles freeze which is a bit of a b*gger Twisted Evil Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #391307 22nd Jan 2015 12:17am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I've used the Hotshot and you still need to get it close to the washer jets, because if the pipes beyond are frozen it can be difficult to clear, although it will work its way along eventually.
I've put my hand in front of the jets hitting the windscreen and it's hot water certainly not 60C.
The AlphaTherm AT-38OD is the same thing and about £60 in the US, I ordered one from amazon.com and it cost about £13 import duty.
Post #391599 22nd Jan 2015 9:35pm
LRmud
Consumerize, I'm looking to position the jets on the bonnet, do you have any measurements?
I would PM you but the info might be useful to others. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #394601 31st Jan 2015 9:21pm
consumerize
Hi LRmud
Below is a picture of the position of my jets, with measurements (excuse mud splats). From Front of bonnet to front of Jet 26cm
From left / right edge of bonnet to centre of jet - 25cm.
I would suggest putting them about 1cm nearer the window, as where i put them went just over the re-enforcing panel under the bonnet, making it a pain to cut the hole.
You may want to just plumb one in initially and hold in that position while someone pushes the washer button. make sure your pump is up to the job. Halford sell two sizes of pipe, I used the thinner one. You have to heat the tube up on the end so it goes a bit soft to fit over the jet nozzle.
I used the rubber washer on the bottom of the jet as an an initial template, cutting the hole smaller and filing away til it slotted in. the slot for the clip at the rear being narrower,as below:
I'd measure the hole for you but they are clipped in so firm now I suspect id break something getting them back out. I had to cut approx. 1mm off the top of the retaining clip to get it to click into place under the bonnet.
I would also suggest masking off the surrounding paintwork with tape, in case you slip with the drill / file.
Post #394743 1st Feb 2015 10:31am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Nice mod Thumbs Up
Is there any adjustment in the nozzles so they can be mounted closer to the windscreen? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #394774 1st Feb 2015 12:18pm
LRmud
Cheers for the info, just what I need. I'll get the drill out later today.
I've got a fibreglass bonnet so drilling holes should be easy enough. I may have to trim a bit more than 1mm off the clips though as the fibreglass is probably thicker than a standard bonnet.
I've made a template already with a piece of plastic sheet so it should be fairly straightforward to mark up.
There appears to be no adjustment on the jets themselves which I thought was a bit of a shame. --------------------------------------------------------------------------------------------------
1989 Defender 90
Post #394779 1st Feb 2015 12:37pm
consumerize
The jets do adjust, they are just extremely stiff. I tried with the usual safety pin, but wouldn't budge.
if you put a small flat screwdriver blade under them and lever it a bit, there is actually a good bit of movement. Mine are set about 3/4 up.
They could probably be set close to the screen than i have them, but id guess about half way along the bonnet would be max to get the elevation of the jet to still hit the windscreen high enough.
The disadvantage of putting them closer I though was id probably have to take the bonnet off to be able to reach to drill the holes. Didn't fancy my chances doing that on my own.
Post #394800 1st Feb 2015 1:44pm
PaulMc
I have these heated jets on my Discovery-2 - I can confirm that they do adjust Thumbs Up
. Paul.
Post #394809 1st Feb 2015 2:35pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Bonnets are easy to remove by one man, ask any the thieving sods that nick em!
Post #394816 1st Feb 2015 2:47pm
Page 2 of 3 <123>
