Home > Puma (Tdci) > Rechargeable battery backup Sounder
Page 2 of 2 <12
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Looks like a great idea will do it myself
Post #305809 7th Feb 2014 8:11am
110 John
richardg wrote:
Just fitted one of these sounders to my Puma. Not the loudest sounder I have ever come across but good enough and as stated above reasonably well made. It is possible to pick up the wiring in the standard vehicle harness so that it gets permanent power plus an alarm trigger signal. If any-one would like details please PM.
Will PM mate
Post #305810 7th Feb 2014 8:12am
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Reply sent, sorry for the delay
Post #306735 9th Feb 2014 11:07pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
The alarm on my puma sounds, when I disconnect the battery (discovered whilst wiring in the delay/spots. I did not opt for the backup battery sounder. Is this standard or do I have something extra?
What us the disable procedure, for future work?
Mark.
Post #306748 10th Feb 2014 1:57am
nitram17
Hi i ordered one of these ages ago ..have not fitted yet! tried it on 12v battery disconnecting either lead and the sounder is dead.......im guessing it will need to charge?or is it duff?i have pm you for fitting instructions as i am clueless with electronics! can you trickle charge this from a charger or do you allow the truck to charge it in situ?
Post #388061 13th Jan 2015 5:30pm
nitram17
ooops how do you delete a double post?
Post #388062 13th Jan 2015 5:32pm
110 John
It will need charged
Post #388070 13th Jan 2015 6:13pm
richardg
Nitram,
PM sent - is it all working okay ?
Richard
Post #388477 14th Jan 2015 7:27pm
nitram17
Richard thanks for info i will fit it at the weekend!
Post #388488 14th Jan 2015 7:55pm
NDF
 2004 Defender 90 Td5 XS CSW Java Black
Resurecting an old post. LR BBUS for TD5 appear to be no longer available, or at least JLR are having trouble sourcing them. No third party appears to have stock, despite what their website may say. So as an interim (?) measure I bought one of the BBUS from the earlier link. Seems OK and looks like it will work as a simple alert if power is cut. So far so good, but has anyone worked out how to wire so it is activated by the alarm? Reset will be with the key on the unit, but it is activated with a + or a ground signal (separate) connections. Fine so far but the 10AS activates the BBUS by replacing a + with a ground on the same connection.
Advise gratefully received.
Post #744793 9th Dec 2018 2:44pm
dorsetsmith
Siren with Battery Back Up - LR044570 - Genuine this can be used instead
Post #744796 9th Dec 2018 3:13pm
NDF
Thanks dorsetsmith. That's the part I have been attempting to obtain. Listed on lots of sites but all have to order from JLR. JLR have none and it is on backorder from whoever made it for JLR. I understand this has been the situation for some time. I have one on order but thought I would add this other BBUS whilst I wait...
Post #744798 9th Dec 2018 3:25pm
Page 2 of 2 <12
