![]() | Home > Puma (Tdci) > Rechargeable battery backup Sounder |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Looks like a great idea will do it myself
richardg Member Since: 17 Dec 2012 Location: Cumbria Posts: 30 ![]() ![]() |
Reply sent, sorry for the delay
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
The alarm on my puma sounds, when I disconnect the battery (discovered whilst wiring in the delay/spots. I did not opt for the backup battery sounder. Is this standard or do I have something extra?
What us the disable procedure, for future work? Mark. |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Hi i ordered one of these ages ago ..have not fitted yet! tried it on 12v battery disconnecting either lead and the sounder is dead.......im guessing it will need to charge?or is it duff?i have pm you for fitting instructions as i am clueless with electronics! can you trickle charge this from a charger or do you allow the truck to charge it in situ? Last edited by nitram17 on 13th Jan 2015 4:34pm. Edited 1 time in total |
ooops how do you delete a double post?
It will need charged
Nitram,
PM sent - is it all working okay ? Cheers Richard |
Richard thanks for info i will fit it at the weekend!
NDF Member Since: 09 Dec 2018 Location: England Posts: 20 ![]() ![]() ![]() |
Resurecting an old post. LR BBUS for TD5 appear to be no longer available, or at least JLR are having trouble sourcing them. No third party appears to have stock, despite what their website may say. So as an interim (?) measure I bought one of the BBUS from the earlier link. Seems OK and looks like it will work as a simple alert if power is cut. So far so good, but has anyone worked out how to wire so it is activated by the alarm? Reset will be with the key on the unit, but it is activated with a + or a ground signal (separate) connections. Fine so far but the 10AS activates the BBUS by replacing a + with a ground on the same connection.
Advise gratefully received. |
Siren with Battery Back Up - LR044570 - Genuine this can be used instead
Thanks dorsetsmith. That's the part I have been attempting to obtain. Listed on lots of sites but all have to order from JLR. JLR have none and it is on backorder from whoever made it for JLR. I understand this has been the situation for some time. I have one on order but thought I would add this other BBUS whilst I wait...
