Home > 130 > weight of 130 double cab. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17566 |
According to Landrover, the "minimum EEC kerb weight" of a 130 DC HCPU is 2153Kg.
This will include an allowance for fuel and driver*, so the ULW is likely to be around 2000Kg. This of course assumes that you haven't have a roll cage, winch, and lots of other heavy items bolted on in which case it will be heavier. *EDIT: It is based on a full tank and a 75Kg driver. A full tank is 75 litres for a 110 or 130 and although the mass of diesel varies according to temperature and density it is typically about 0.9Kg per litre, so the fuel in a full tank will be approximately 67.5Kg. Add in the driver and that makes 142.5Kg, so the ULW will be approximately 2010.5Kg. This is better news that you might realise, since having a ULW under 2040Kg means that the vehicle is legally defined as a Dual Purpose Vehicle under the Construction and Use Regs and enjoys all the benefits that this endows. |
6th Jan 2015 9:55am |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
Thanks, got a bit of a road trip to do. Derby to Perth and back. Will post pictures once collected.
6th Jan 2015 10:20am |
After one very long day on Sunday its home.
13th Jan 2015 8:34am |
Click image to enlarge |
13th Jan 2015 8:37am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
13th Jan 2015 9:04am |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
yeeeeeer nice.
13th Jan 2015 9:39pm |
Nice! What are your plans for it?
Is that a 14 foot trailer, by the way? I am a little disturbed by how badly I want a 130! |
13th Jan 2015 10:45pm |
Dont wory blackwolf its normal
14th Jan 2015 7:55am |
I keep regretting that I didn't buy J-Lo when you sold her!
Speaking of which I see Nene's no longer advertising her so I presume someone bought her in the end. |
14th Jan 2015 8:11am |
Thanks. I've got to say AndrewS for a long time I have been looking in your gallery and I hope one day I will have this as clean and as nicely put together as all your 130's.
I think mine was a bit of a bargain really. It has sat in a shed since 2011 so needs a little bit of work. It needs a batch on the front nearside outrigger to get it through mot and it has a knocking in the gearbox which I need to figure out.It's getting complete service throughout including cambelt. But other than that it's solid and just needs tidying up. I need to buy or make a back for it and then just use it for work really. I would like to get some 285's or 33's on and do a few other litttle bits but I'm in no rush as a plan to keep it for a long time. Yes it is a 14ft trailer. It towed really well, it got a flat tyre on the way back which wasn't a problem. We were back on the road 25 minutes later but 5 miles down the m6 the spare that we put on blow out. |
14th Jan 2015 9:38am |
Thanks for confirming the trailer. I needed to buy an IW trailer last year, and opted for the LM146 on the basis that one day it will be useful for collecting my 130! I figured that one would just fit, so it's good to know that I was right and am not going to regret not going for the 166.
14th Jan 2015 2:28pm |
130, mans truck (unless full of quilted leather)
14th Jan 2015 2:48pm |
Quilted Leather Eh and exactly why have you been googleing that
Oh ER |
14th Jan 2015 3:07pm |
she needs some hot dinners !!
14th Jan 2015 4:55pm |
