Home > Technical > Diff Housing Stud Replacement |
deep down Member Since: 02 May 2012 Location: France Posts: 204 |
The lower stud on the rear diff housing has taken some damage and the thread is now stripped, as a result I have a slight weep of oil.
Looked through the manuals but can't seem to find anything. Has anyone changed one out? If so where did you get the new stud from. Thanks in advance. |
12th Jan 2015 1:01pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2225 |
These are the ones for the rear I believe:
http://www.brit-car.co.uk/search.php?xSearch=561196 Although i believe a different length is listed for drum brake axles. Steve 02' 110 TD5 Double Cab Rebuild Thread |
12th Jan 2015 1:07pm |
Thanks for that.
Just found them on LR Direct as well. Looks like its half shafts out, diff out then hammer the stud through and hammer the new one in. Simple......... Another Saturday morning project. |
12th Jan 2015 1:51pm |
I would say use a socket and g-clamp to press old one out and new one in to reduce the chance of damage to the sealing face of the axle casing
12th Jan 2015 2:39pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
14lb sledge hammer to get the diff off the axle once the nuts are undone and plenty of sealant to refit with
12th Jan 2015 8:19pm |
Any thing extra to consider as it's an ARB locker?
13th Jan 2015 3:49am |
