Home > Technical > Diff Housing Stud Replacement
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
The lower stud on the rear diff housing has taken some damage and the thread is now stripped, as a result I have a slight weep of oil.
Looked through the manuals but can't seem to find anything.
Has anyone changed one out? If so where did you get the new stud from.
Thanks in advance.
Post #387695 12th Jan 2015 1:01pm
rallysteve
These are the ones for the rear I believe:
http://www.brit-car.co.uk/search.php?xSearch=561196
Although i believe a different length is listed for drum brake axles.
Post #387698 12th Jan 2015 1:07pm
deep down
Thanks for that.
Just found them on LR Direct as well.
Looks like its half shafts out, diff out then hammer the stud through and hammer the new one in. Simple......... Shocked
Another Saturday morning project.
Post #387712 12th Jan 2015 1:51pm
rallysteve
I would say use a socket and g-clamp to press old one out and new one in to reduce the chance of damage to the sealing face of the axle casing Smile
Post #387716 12th Jan 2015 2:39pm
Fatboy Slim
Wales
14lb sledge hammer to get the diff off the axle once the nuts are undone and plenty of sealant to refit with Thumbs Up
Post #387821 12th Jan 2015 8:19pm
deep down
Any thing extra to consider as it's an ARB locker?
Post #387937 13th Jan 2015 3:49am
roel
You have to be carefull with the airhose on the outside and the airpipe on the inside. That's all. Roel
2003 90 Td5 (2009-now)
Post #387941 13th Jan 2015 5:11am
