Home > Puma (Tdci) > New owner, unhappy owner |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Hopefully you will be ok.
However you should have checked the oil level the day you bought it. What year is the car |
10th Jan 2015 11:48pm |
nielsds Member Since: 10 Jan 2015 Location: Antwerp Posts: 14 |
Indeed, I should have done that, not so smart.
Thx for your sympathy Last edited by nielsds on 11th Jan 2015 12:17am. Edited 1 time in total |
11th Jan 2015 12:12am |
I would get it serviced immediately and a full health check which I'm sure you're going to do.
Once you have a clean bill of health I'm sure you can sit back and enjoy your ownership. They are great cars and will go anywhere. Good luck and don't worry too much. |
11th Jan 2015 12:16am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1766 |
Flex the credit card!
Full service, every oil, filter, belt, fluid, brakes etc. do it now, do it once & properly and then enjoy! Keith |
11th Jan 2015 12:24am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 573 |
AS Ickle said. If the engine oil is that low you dont know what the other levels are like. Change all,oils and filters,& moniter levels for a while,at least then you know all is good. Marc |
11th Jan 2015 11:18am |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
Hi, while it's bad to see an oil light at any time in a way it's good that the oil light came on because the oil level was low, if it came on when there was plenty of oil in it then you really would have problems. Hopefully a thorough service of everything and you'll be OK.
Good luck. 2.2 90 XS 88" Series One Old Norton Minerva |
11th Jan 2015 11:46am |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
remember your consumer rights, in the UK we have rules in place ....
http://www.tradingstandards.gov.uk/advice/...s-sum6.cfm could be that the service didn't fill wit the correct levels, it can use oil, its an engine, they all use oil...at differing rates. keep an eye on it. |
11th Jan 2015 12:03pm |
Thx for your reaction !!
Wednesday he will be at the shop.. ! lets hope not to much bad news. Friendly regards, Niels De Saedelaer |
12th Jan 2015 5:25pm |
Niels, ben je zeker dat je de juiste vlag hebt gekozen onder je locatie? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Jan 2015 5:46pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2293 |
Hello nielsds
Well you will find out, but let's hope you are OK As Jay Boy / ickle and sharkey964 have pointed out Your next move is to fully service it... As for your rights, unless wrongly described, 'caveat emptor'... buyer beware. Good luck SKIP https://www.defender2.net/forum/topic83242.html |
12th Jan 2015 6:16pm |
Belgische vlag toch ? ben niet helemaal mee ? |
12th Jan 2015 11:20pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Zoek je een goeie garage: Alanius in Zoersel.
Met de groeten van Zone30! Nederlandstalig forum: www.xrover.be Last edited by zone30 on 12th Jan 2015 11:30pm. Edited 1 time in total |
12th Jan 2015 11:28pm |
Daar gaat hij ook binnen !!! ben er al heel goed geholpen alsnog bedankt voor de tip
12th Jan 2015 11:29pm |
Nu zie ik het , merci ! |
12th Jan 2015 11:30pm |
