Home > Puma (Tdci) > door trim clips for puma
TheTechnobear
Spain 2007 Defender 110 Puma 2.4 SW Chawton White
hi there,
i need to remove the rear passenger door trim, to fix the door handle which is a bit loose.
i understand that the clips might break, so i thought id order some first...
anyone know the part #?
i thought its was MXC1800, but when looking on ebay, here ,it implied not
is there anything, that is likley to need replacing eg. sacks?
thanks
Mark
Post #100547 17th Nov 2011 3:51pm
SGH
here http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...370wt_1413 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #100567 17th Nov 2011 6:36pm
ZeDefender
Re: door trim clips for puma
TheTechnobear wrote:
hi there,
thanks
Mark
Perhaps it would ease your mind to know that even I (ham-fisted as I am) recently managed to get the trim off and on again without breaking any clips! Just remove the grab-handle and the plastic door-latch flap and work your way around, gently pulling back to release one clip at a time. There is one final clip right in the middle which I was a bit worried about, so I unhooked the trim from the clip by lifting it upwards (before refitting take it out of the door and put it back in the trim so you can pop it back in again) Thumbs Up Tell someone you love them today because life is short.
Post #100626 17th Nov 2011 10:18pm
TheTechnobear
Thanks for that.
Are these similar to the ones used on the rear (tail) door, as I managed to get those off (when fitting wheel carrier) without breaking any Smile
Post #100631 17th Nov 2011 10:25pm
ZeDefender
Thanks for that.
Oops Embarassed
Sorry, I have lost the ability to read - I was talking about the rear door Thud Tell someone you love them today because life is short.
Post #100632 17th Nov 2011 10:28pm
Killer90
Site Sponsor
is it your rear door or the middle row doors if you get a trim tall or flat screwdriver you can prise them off easily with out breaking them, what handle is it you are doing up because most of the handles eg grab handle and the open/close handle can be tightened without removing the door cards Thumbs Up
Post #100652 17th Nov 2011 11:44pm
TheTechnobear
rear passenger door trim - i only mentioned the tail door as i wondered if the fixings were the same, as id removed that before. sorry for confusion.
does everyone refer to the doors as middle or 2nd row doors then?
anyway, the LH 2nd row door handle is loose, in fact if the door is locked, you can pull it away from the body work.
looking at the workshop manual, it appears its connected inside with 2 screws, one at each end... im guessing one has come out, and its only attached by the opening mechanism. but will only know when trim is off.
cheers for help
Post #100693 18th Nov 2011 11:47am
nielsds
Belgium
any idea where to get the red part ? http://www.defendersource.com/forum/attach...1260132339
Post #387742 12th Jan 2015 5:36pm
SGH
You need to buy new door card to get the red part.
The white clips don't often break it's the red part that usually breaks.
Post #387748 12th Jan 2015 5:58pm
nielsds
Belgium
Thats creazy.. a new doorcard just for that... ?
Post #387882 12th Jan 2015 11:19pm
