Home > Maintenance & Modifications > A different slant on door security |
there bullet locks same as used on roller shutter doors etc
31st Dec 2014 2:31pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
I contacted him about a week ago to see if there was a 110 version. Havent even had a reply...
1st Jan 2015 12:00pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Me neither, I messaged him through eBay on 24th. How did you talk with him Teryt ? 110 Hardtop
1st Jan 2015 2:14pm |
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 |
Call him on 07776373632
He was certainly taking calls yesterday. |
1st Jan 2015 2:18pm |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 |
Looks great Nige ..how was the door fitting .not fitted mine yet .job for tomorrow ...
Are the bolts long enough to go through the bracket. Terry |
10th Jan 2015 6:33pm |
Picture below of inside. Plenty of bolt length but the nut tries to do up on an angle which when tightened make the bar go on the slant on the outside. These little brackets solved the problem and got the bar sitting square again.
Click image to enlarge ...and I owe you a picture of the back door lock. Click image to enlarge Very happy with it all. Should slow the down a bit. Nigel |
10th Jan 2015 7:19pm |
Excellent thanks for that.sorry to keep asking questions .the front door I take the door card has to come off etc,
Like the bracket idea. Looks like a neat job mate. Terry |
10th Jan 2015 7:22pm |
Yep, door card half out. I just took off the interior door handle and the internal opener, pop the fast clips and you have enough access to put the nuts on.
You will need to cut the bolts down by about 20mm otherwise they stop the window winding down! Good luck. |
10th Jan 2015 7:27pm |
Cheers mate ,thought they might be a little long ..
I'll post pictures when done. Terry |
10th Jan 2015 7:32pm |
Click image to enlarge Click image to enlarge Good afternoons work. |
11th Jan 2015 4:51pm |
Nice job Terry. What did you think of them?
I see you fitted yours a bit higher than I did. How did you cope with the angle on the inside? Nigel |
11th Jan 2015 4:54pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Just out of interest whats there to stop someone undoing the door hinges and just pulling the door forward out of the side piece? Just out of curiosity ?
11th Jan 2015 4:57pm |
Only epoxy in the door bolt heads, but it does make it a tad more difficult.
It's just the first layer. Hopefully it's enough to make them pass it by as very visual, and the second and third layers don't even have to do their jobs. |
11th Jan 2015 5:08pm |
Click image to enlarge Have to say mate I found fitting them easy ,but your tips helped a lot .i used heavy steel washers on the inside which pulled it all straight. As Nige says its a layers security approach with my other things in place it should make a difference.taking off doors takes time and the original locks work as well. Nice item and easy to fit ... Terry |
11th Jan 2015 5:36pm |
