Home > Maintenance & Modifications > Fuse Panel Corrosion - 110 300tdi Station Wagon
Defenderbub
United Kingdom 1986 Defender 110 300 Tdi CSW Barolo Black
I have noticed some corrosion on the fuse panel in my 300tdi County and I wanted to ask if anyone can recommend a contact cleaner that is ideal of the fuse board - can I use for example ACF-50? Any advice much welcome.
Post #387092 10th Jan 2015 6:45pm
leeds
Am not sure how good ACF 50 is at cleaning electrical contacts. Would suggest purpose made Electrical contact cleaner which should be available in your local motor shed
We have some marine/electrical engineers on board so will be interesting to see what they recommend..
Brendan
Post #387099 10th Jan 2015 6:53pm
Defenderbub
Many thanks Brendan, look forward to their suggestions, in the meantime this may just be what I am after:
http://wd40specialist.com/products/contact-cleaner/
Post #387101 10th Jan 2015 6:56pm
Taken directly from the uK website:
"ACF-50 contains no water and is approved for electrics so spray directly into electrical joints and components where it will prevent corrosion induced failures and high resistance joints.
ACF-50 has strong capillary action so will creep into all the areas that moisture can, 'actively' pushing out moisture and replacing it with protection."
Post #387126 10th Jan 2015 7:24pm
Defenderbub
Thanks, I will dig around a little more but this seems like it would do the job.
Post #387311 11th Jan 2015 8:52am
K9F
I would disconnect the battery and remove all the fuses, liberally spray the board with a 'branded' contact cleaner such as the one in your link and 'work it in' with a stiff brush. Once finished wash down with the same cleaner and wipe off any residue.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #387323 11th Jan 2015 9:55am
munch90
really contact clearer is only to clean oil grease etc from electrical things as far as I know , ive never found one to clean corrosion
as k9f it really needs cleaning properly
I would remove all the fuses , making a note of where they went , spray with acf or wd etc , when a while then using a very thin flat file give each fuse slot a clean ( use something like a modellers file ) making sure you don't open the slots up so fuses are loose , then rinse with acf or wd , and if poss a compressed air blow out , then respray lightly with acf / wd so prevent new corrosion
refit fuses in correct places
Post #387350 11th Jan 2015 11:24am
Defenderbub
Thanks one and all - I think I just need to stop any more corrosion and the WD or ACF would do just that. I will report back one the job is done - I will disconnect the battery, photograph the panel, remove the fuses, spray, wipe, clean, etc.
Post #387880 12th Jan 2015 11:17pm
