Home > Puma (Tdci) > Water on passenger side floor mats Defender Puma? |
OleDave Member Since: 19 Oct 2013 Location: CARDIFF Posts: 175 |
No probs DaveGL, wish I could have offered the total solution for you.
Had a bitter disapointment today when I went out in lovely girl guess what!! there was a pool of water on the passenger side again! looks like the snow cowl was not the answer damb it!!! next step is to dismantle some of the dash on the passenger side and get the Boss, ( She who must be obeyed!! ) to play water over the screen and surrounding area while I sit in there with my torch to see if I can spot where its coming in, it could be like your problem the screen rubber, its looking like the culprit more and more. Watch this space!! Regards Ole Dave |
10th Jan 2015 2:09pm |
DaveGL Member Since: 19 Dec 2014 Location: Surrey Posts: 57 |
Why don't you try what I did, get some kitchen towel and fold it into the gap between the back of the dash and the bottom corner of the windscreen. If the kitchen towel is wet after it rains, you know where your culprit is.
Good luck! |
10th Jan 2015 3:08pm |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 |
Hi Had Defender back from dealership - New door seal to passenger door - New seal along base of windscreen surround all appears good, happy with the dealership, they could not be more helpful so praise from me to Stratestone Newport as I have had issues with other Stratstone dealerships in the past. RAI fitted as well |
10th Jan 2015 3:55pm |
Hi Guys, pleased to advise have cured the leak eventually, more by luck than by design!
As mentioned I bought some Captain Tolley and went around the bulkhead seals and everywhere I could think of without any sucess, was sat here one day recently head in hands thinking about when to take the dash out and a thought crossed my mind, there was only one place I had not tried the Captain Tolley and that was around the threaded area of the wiper extension where they bolt through the bulkhead, I applied the Captian Tolley to the threads on the outside and it just vanished down between the nut and the threads in seconds!!! over a period of a few hours I applied more until it would not take anymore, Success!! no more water on the mat!!! Thought this might help others as its worth checking before taking the dash out. Hope all, you guys are well Ole Dave |
5th May 2015 3:04pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
Cheers Dave, I to have been all round mine with the captain Tolley so will try where you say and report back in a week or two.
5th May 2015 8:49pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Need to try some Captain Tolleys on my wiper spindles, the dealers had my 110 for 2 weeks to try and cure the water ingress, they fixed the water getting in the windscreen seal and fitted a new seal between the screen frame and bulkhead.
I still have puddles in the drivers footwell and the wiper box on the drivers side is getting really noisy, I'm thinking this could point to water weeping in the spindles as you have discovered. Thanks for your efforts Dave 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
6th May 2015 5:35am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1317 |
Following this thread with interest as I too have a passenger side leak.
My vehicle is going in to the dealer on Monday to have the leak investigated at the same time as they sort out the oil pump recall. I've also mentioned to them that the drivetrain is far more clunky than my previous 2.4 which had three times the miles on it. Pretty sure it's just your standard Defender sloppy transmission, but I thought I would let them take a look whilst they are doing the other work. Primarily though I am hoping they can sort out the leak. If they can't then I will try the spindle treatment. Thanks for the info Dave. |
9th May 2015 8:32am |
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 |
Maybe you have sorted te leak by now but I have just found the root of the problem on mine.Water find it way intothe engine compartment under the windsreen area and leaks in through one ofthe bolt holes which secure the fan assembly
Dave |
12th May 2015 12:20pm |
