Home > In Car Electronics > DAB aerial sent FM Squiffy |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Try running a chunky cable from FM aerial to engine block to check if its an earth issue for the aerial
If FM aerial is amplified, check power supply to aerial |
4th Jan 2015 7:59pm |
Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122 |
Thanks kmac!! It's the standard 2004 Land Rover aerial, would this have an earth normally and where might it be? Wondering if I've dislodged it somehow if it happened to be behind the dash?
Thanks!! |
4th Jan 2015 8:09pm |
It is easy to damage the standard aerial if you have pulled the cable through the bulk head a few times
The earth in the standard aerial is from aerial connecting to the wing at point where it is attached to the car. There is no additional cable. If you have a multimeter - check that the outer section of the aerial plug has continuity to the part of the aerial that touched the wing (underside of wing) Also check that there is no short from tip of aerial plug to part that of aerial that touches underside of wing ( this should be complete open circuit) |
4th Jan 2015 9:30pm |
Hey, well i removed the dab aerial and wiring and guess what, went back to normal! I can only assume the dab aerial cable was providing some sort of bad interference.
I'm now going to go down the route of a splitter Thanks for the help! |
7th Jan 2015 6:45pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
I thoroughly recommend the Kinetic 7002 splitter from DAB on Wheels, not cheap but it sure does work
We live in a very marginal DAB area and I get excellent reception. Tested it between Somerset and Berkshire a few times, using the A303 which has a few bad reception areas on FM, and DAB reception has been faultless. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
7th Jan 2015 7:15pm |
Cheers Bob!
When you installed it, does it need a separate 12V feed or will the antenna power supply work (my radio can supply power via the Dab aerial cable)? It does look good, they do a slightly less expensive powered one at 49, may get that! |
7th Jan 2015 7:19pm |
They suggest taking the feed from the switched input power supply to the radio, which I did.
The instructions do tell you to switch the DAB aerial feed off. Very easy to take the feed from the switched supply, once you have found it ! I stripped the insulation off and soldered a new wire inline, insulated it all up and fitted a male bullet connector to the other end. Put a female bullet on the splitter 12v supply, connected up and job done. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
7th Jan 2015 7:39pm |
