Home > Technical > my mrs 90 no drive !!!!!!!!! |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Yep, common problem although quite straight forward to repair, if your handy with the spanners!
Done one a few weeks ago, mine is next!! Good luck in getting it sorted 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
5th Jan 2015 8:50pm |
defenderq Member Since: 04 Jan 2015 Location: oxford Posts: 18 |
cheers....found local landy place that will do it ... guy bought it from will pay for repair but no transport.....£450 down and its still on me drive would have been easyer doing meself ..... parts £70 ...i suppose if its not just shaft the guy will cover it...bet it snows before we get it back....aaaahhhhhh
6th Jan 2015 5:31pm |
Is it a tdci? Or td5,300tdi?
Just asking as all the parts for tdci amount to around £150 so make sure you have been quoted for correct parts. But if it's td5 might just be input shaft? Tdci have a different problem/set up, intermediate coupling shaft which fails! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
6th Jan 2015 5:52pm |
its a 2010 2.4 tdci i think...found part numbers and found bits on ebay...im not paying for parts or labour just the transport. Looked at job and if it wasnt under warrantee would do it me self....its all kinda guesswork till they pull it apart, there did seem to be a small amount of rust at the bottom of the tunnell between gear box and transfer box. there was a small hole kinda semi circle (drain hole ? ) and rust seemed to be coming from there...Maybe thats cause landrover dont greace them..
6th Jan 2015 6:22pm |
Don't recall any holes in that section of the box, but sounds like someone's been there before!
Maybe trying to spray some lube inside? Only way to lube it is to pull it apart, maybe water has entered the hole and rusted the splined shaft? Would be interesting to see it once it's out! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
6th Jan 2015 6:29pm |
If you look back in the puma section on here you will find the post "another one with worn splines"
That was the one I done a few weeks ago, just so you know what sort of job it is, Grease nipples are the way to go!! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
6th Jan 2015 6:33pm |
but to be fair was in layby with aa mans torch so will have another look...greace nipple would be cool....and if they have any left over could put them in wiper stems !!!!!!!! will check puma post cheers
6th Jan 2015 6:44pm |
Ahhh the joys of owning a landrover!
"It does get better" At least that's what I was told! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
6th Jan 2015 6:50pm |
just checked out puma post good pics and info....funny if these cars we cherish so much where chinease pit bikes you would be anoyed but fair doo... it was £125 quid off ebay but the whole think stinks really should be a free upgrade kit with greace nipples ....its pretty poor ... like my spelling !!!
6th Jan 2015 6:54pm |
when its all done ill be in love again ...but im £450 quid down 4 weeks into ownership ,just after christmas and mrs needs car for work she is a nurse whole point of "reliable Landy" she is now driving £600 quid matiz my daughter in law has had for two years no probs ... you could go off road in matiz just pick it up put it in your pocket walk accross field then get back in it...deep joy..landy does still look pretty on drive
6th Jan 2015 6:59pm |
yes there is a small cut out in one end of the casing between main box and t/box as standard , only small about 3 - 4mm wide and about 8 -10mm long , just a small drain hole if i remember right its in gearbox end on the mating surface |
6th Jan 2015 7:22pm |
like the kiddy ..... think the rust is coming out of there ...when it lost drive there was no warning other than a couple of clonks then bang crunch ..no drive... maybe clutch gone too ?
6th Jan 2015 7:32pm |
The high/low lever hasn't dropped into neutral has it? Sorry if it's a daft question.
Ray |
6th Jan 2015 7:37pm |
question but no .....high dif lock nothing ...low dif lock nothing ...high / low nothing ... kept thinking migh be that ...wish it was .....makes a cool grinding noise if you lift clutch with every thing engaged
6th Jan 2015 7:49pm |
