sparkylee
Fan heater controller not working | |
I noticed yesterday when popping to see Albion to pick up some goodies that I was either cold or unbelievably hot ......
The fan seemed to only be working on 3 not either 1:2 with no A/C on
So I've been testing today and the same thing is happening
1:2 not working only 3 without A/C on
If I turn off blower and put A/C on I hear fan start to run at 1 turn fan speed controller to 1 stays on and if I select 2 it stays at 1 only speeding up at 3
Am I right in saying fan gets supply from switch via resistor pack for speeds 1:2 and direct for 3 and direct from A/C for minimum setting of 1 ?
So I'm thinking resistor pack on side of fan motor under bonnet is at fault ?
Think LRs self distruct timer is out as this has cropped up 12 days before warranty expires
Normally due to start going wrong 1 day after It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
5th Jan 2015 12:56pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
