Home > Puma (Tdci) > Speaker Headlights
Mac22
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Speaker Headlights
Hi Gang,
Looking for a tad of advice.
I have a set of Speaker headlights due soon and I don't know if there will be issues wiring up my main beam lamps there now.
Please see piccy.
My main beam is separate to the headlights that will be replaced.
So when the new H/L's are fitted do I run a feed from the original main beam lamps to the new H/L's to activate the main beam in the new ones as well as the original lamps.
If so, do I fit anything inline (resistor / relay / wing & a prayer).
Cheers in advance....
Mac.
Post #384439 3rd Jan 2015 11:42am
if you got them from the mobile centre Tim does a Loom always worth a call / mail
I have the same set up with the Xtech Thumbs Up Thumbs Up
Post #384450 3rd Jan 2015 12:25pm
Mac22
Cheers Ken
Called and message left.. Thumbs Up
Post #384461 3rd Jan 2015 12:58pm
ericvv
Re: Speaker Headlights
Mac22 wrote:
Hi Gang,
Please see piccy.
Mac.
Mac, not sure what you are talking about here. In your picture is the regular SVX front. That has a main 7 inch headlamp which has a high/low function. Additionally the SVX front has the 90mm auxiliary high beam lamp, which with high beam is additional to, but does not replace the high beam of the main headlamp.
So if you have the standard SVX lamp set up without modifications, you just replace your halogen 7 inch main headlamp by the Speaker headlamp, with the standard plug, and this will like with your halogens give you high/low beam.
You do not touch the 90mm aux headlamp, like before, that remains a additional aux high beam lamp.
Hope clear, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #384476 3rd Jan 2015 2:03pm
Eric is spot on it was another project Tim assisted with a loom Rolling with laughter
Post #384493 3rd Jan 2015 3:32pm
dgardel
Italy
and now
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #384499 3rd Jan 2015 4:13pm
Mac22
Cheers Eric,
I thought the aux lights were the main beam....Doh!!
My 7" headlights do side lights / normal lights and high beam.
So it should be a simple plug and play jobbie..
Thanks for the responses Gents... Thumbs Up
Post #384572 3rd Jan 2015 7:20pm
ericvv
Post #384573 3rd Jan 2015 7:24pm
dgardel
Italy
Mac22 wrote:
Cheers Eric,
If you just have the SVX and the JWS with side lamp, the job is 95% P&P
Just install the Defender light frame, connect the side light to the JWS wires (better if you add a sealed connector, this is the 5% not P&P part), With a multimeter che the positive (+12V) when the side/marker is ON.
Connect the single cable from the JWS to this one
plug the H4 connector, fix the lights,
job done!!!
For more detailed pics look here: http://www.defender2.net/forum/topic15159.html
IID Pro MV License
Post #384708 4th Jan 2015 1:42am
