Home > Puma (Tdci) > Speaker Headlights |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
if you got them from the mobile centre Tim does a Loom always worth a call / mail
I have the same set up with the Xtech |
3rd Jan 2015 12:25pm |
Mac22 Member Since: 22 Nov 2013 Location: Merseyside Posts: 675 |
Cheers Ken
Called and message left.. |
3rd Jan 2015 12:58pm |
Mac, not sure what you are talking about here. In your picture is the regular SVX front. That has a main 7 inch headlamp which has a high/low function. Additionally the SVX front has the 90mm auxiliary high beam lamp, which with high beam is additional to, but does not replace the high beam of the main headlamp. So if you have the standard SVX lamp set up without modifications, you just replace your halogen 7 inch main headlamp by the Speaker headlamp, with the standard plug, and this will like with your halogens give you high/low beam. You do not touch the 90mm aux headlamp, like before, that remains a additional aux high beam lamp. Hope clear, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
3rd Jan 2015 2:03pm |
Eric is spot on it was another project Tim assisted with a loom
3rd Jan 2015 3:32pm |
Click image to enlarge and now Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Jan 2015 4:13pm |
Cheers Eric,
I thought the aux lights were the main beam....Doh!! My 7" headlights do side lights / normal lights and high beam. So it should be a simple plug and play jobbie.. Thanks for the responses Gents... |
3rd Jan 2015 7:20pm |
Look at it from the bright side.... We have not two, but four high beam lamps.
3rd Jan 2015 7:24pm |
If you just have the SVX and the JWS with side lamp, the job is 95% P&P Just install the Defender light frame, connect the side light to the JWS wires (better if you add a sealed connector, this is the 5% not P&P part), With a multimeter che the positive (+12V) when the side/marker is ON. Connect the single cable from the JWS to this one Click image to enlarge plug the H4 connector, fix the lights, Click image to enlarge job done!!! For more detailed pics look here: http://www.defender2.net/forum/topic15159.html Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Jan 2015 1:42am |
