Home > My Defender > What Did You Do In Your Defender Today |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Removed the Motolita and put the original steering wheel back in the 130.
Car will be off to the dealer once more in a couple of weeks for it's maintenance and the dealer is trying to get someone from Land Rover over to fix the indicator stalk problems I'm having since new. Almost 2 years now... Really hoping they will fix it for once and for all as I'm getting fed up with it. No fun driving through cities like Amsterdam with cyclists not knowing which direction I'm heading. |
1st Jan 2015 1:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20557 |
Took my HU out again in prep for some new work being done shortly.
About it really for today, pretty boring. |
1st Jan 2015 2:33pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Took a headlight out to see how bad the rust is behind in preparation for fitting new crystals, gonna have replace all screws adjusters bezels and shrouds. My 109 thread
my youtube channel |
1st Jan 2015 2:38pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 |
Fitted quad DRL bumper and completed the wiring. 2008 Defender 110 XS SW - M57N2 / 6HP28X
1st Jan 2015 6:22pm |
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 |
Went paddling...
Click image to enlarge |
1st Jan 2015 9:22pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Gave mine a bit of a wash after all the wind we had last night. Loads of leaves and bits of tree all over it
2nd Jan 2015 5:57pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
Booked Beastie in for a service at MJ Fews for end of February
Adjusted the Bump Stops, only to find it looks like they had already been done. Pressure Washed the underside again trying to get rid of the left over Imber mud. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
2nd Jan 2015 6:17pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Picked Rocky up from Harrwoods Pullborough after having turbo hose recall done and handed back the keys to the RRSoprt we've had while they sorted it and did its first MOT which went without a hitch
Glad to have the DC back Can't count the amount of times I've been thinking I'm just going to pop outside to have a fiddle and play and he's not been there Oh and just as they were going to hand it back the driver came in and said it hadn't been cleaned would I like it done so I said yes if it's no trouble ! To which he said no problem not been cleaned since the Def 2 trip to the plains He said it would be about 20 mins it took 1 hr but the have done a cracking job Bet the car wash bloke thought he'd got away with not doing it So we did have plenty of time to look round a good selection of LR cars including a bowler 90 It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
2nd Jan 2015 6:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17519 |
Replaced both wiper wheelboxes and the drive cable. Not a nice job on the Puma due to the one piece dash and the need to get behind the demister ducting - it's a dash out job!
4 hours start to finish, including some other inside-the-dash jobs whilst access was possible. |
2nd Jan 2015 11:05pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
4 hours? That's good going. Just finished putting mine back together having had one wheel box seize Christmas Eve. It worked one second then seized solid the next. The other was about to go too. Apart from the lack of grease in them they were full of sanded down paint from when it had warranty work done. Hunters of Chester and their body shop!!
For anyone that has had paintwork done around the windscreen under warranty, it would pay to pull the whole dash out to see whether they cleaned all the mess up. If not, it will be in the wheelboxes, heater ducts, electrics, everywhere, etc, .... |
3rd Jan 2015 1:20am |
I've had rather too much practice taking the dash out, and after a bit of practice it can be done quite quickly. Like yours, the symptoms mine were giving were irregular swept arcs and the n/s wiper occasionally just locking up. |
3rd Jan 2015 9:32am |
Nothing in the Defender today as it rains and that becomes a salty mix on the roads now, but I did something for the Defender today.... The quarterly map update for the Garmins, first for the original Nüvi 750 which was standard Land Rover equipment for the SVX, and second for the Nüvi 770 which I bought later for the SVX in order to have bluetooth for the phone....
Eric Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
3rd Jan 2015 6:04pm |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
Fitted my new interior lights
Click image to enlarge Gave it a quick wash down whilst on the drive just to get rid of today's road salt. When my attention is drawn to a new shape light metallic grey Transit flat bed (TGB's?) x3 up cruises slowly by, not once but twice Truck now locked, primed, garaged, blocked-in & my phaser is set to stun... TT "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
4th Jan 2015 4:28pm |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
best of luck TT.
4th Jan 2015 4:45pm |
