Home > Puma (Tdci) > 2.4 Puma engine failing at 2000 rpm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
Hello! I have an issue I believe is not rare, but I could not find another post describing exactly the same symptom. Everybody seems to have hard engine failures, but I think this is different, as it is not really hard.
Suppose I'm in 2nd gear and going on a flat road, with engine using almost no power. When I start pressing the accelerator pedal, like if I was speeding up to change to 3rd, the engine fails randomly. It doesn't really fails, but the acceleration is not smooth as it should, even if I take very easy with the pedal... It generally happens when accelerating from, say, 1800rpm, up to a bit over 2200rpm.
The same symptom occurs from 1st to 2nd or from 3rd to 4th.
My first guess is it could be related to the turbine, as it actuates around 2000rpm, as far as I know... Another thing that makes me think about the turbine is that, if I go up to 3000rpm and change to the next gear (while the turbine is still rotating very fast), there is no power loss.
What do you think? What should I inspect?
Thanks a lot! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #383279 30th Dec 2014 2:27am
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
Hey AlexSmith,
I think i have the same thing as you, but couldn't find a solution yet, just had an engine remap done, and the problem seems to be gone, but wait and see.
Tim
Post #383346 30th Dec 2014 1:31pm
AlexSmith
Hello, Tim!
I went to my mechanic a few days ago and he [sic] "reset the ECU to its defaults". After that, he said, I should test to see if the problem was gone, but that didn't happen.
If you don't mind, please post your experience after the remap.
Alex. 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #383352 30th Dec 2014 1:54pm
Zouritte
ok i did a thorough test today and it's still here, but much less present than before. Yesterday while i was testing the new remap i went really high in the RPMs and my guess would be that it helped maybe clean a bit the engine... this is just suppositions... maybe you could try this...
Still investigating, the EGR(as its off in the remap) is not in cause, neither is the ECU... as you said the turbo could be... quite an expensive piece though...
Tim
Post #383380 30th Dec 2014 4:51pm
Zouritte
Post #384685 4th Jan 2015 12:11am
AlexSmith
I read the entire thread and it really seems to be the same or at least a very similar problem. And it enforces my suspects of a problem with the turbo. Scary... I'll try taking the car to a mechanic to have the turbo fan tested. 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #384701 4th Jan 2015 12:54am
Lorryman100
Check the loom around the Turbo modulator for damage. Also remove the modulator plug and look for any damaged wiring into plug. Follow the loom around the engine (No 1 in below diagram, modulator plug is circled) to the PCM and check for damage especially around where the red engine lift bracket is.
Turbo, modulator plug is near No 3 in below diagram,
Land Rover Tech bulletin on stretching of harness affecting Turbo.
HTH :thumbsup:
Post #384706 4th Jan 2015 1:22am
AlexSmith
There should really be a "thanks" button in this forum. Smile
Thank you VERY MUCH!
I'll check this out and post the results as soon as I can.
[off-topic begins]
It won't happen very soon, though, since I'm going out for an expedition tomorrow and will be back in around 30 days. BTW, anybody who's interested in knowing more about South America can follow the expedition at www.ricaamerica.com.br.
[off-topic ends] 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #384707 4th Jan 2015 1:31am
Eduardo
Alex,
When you expect to be in the Patagonia - Tierra del Fuego?
I will be there during February (31-27 Feb).
Maybe we can meet somewhere.
Cheers! Eduardo
Post #384712 4th Jan 2015 4:43am
Zouritte
Hi,
I've checked the loom your are talking about in the surrounding of the turbo but mine seems to be fine, though i've checked the movement of the actuator lever, and it seems to be fine but the sound it makes ( i guess in the exhaust part of the turbine housing is quite metallic is that normal? shouldn't it be lubricated ? Depending on the angle i was moving the actuator lever, i could feel a bit of resistance in the movement.
Don't really know what to think about it.
Do you think this resistance is normal as the blades rub against the housing?
Tim
Post #384780 4th Jan 2015 12:55pm
RafaBr
Brazil
Alex
Mine was doing this only on sea level, you can try disconnect the EGR plug and go for a run to see if it's better. I did this and no more hesitating, less smoke and better mileage. This will generate an error and the MIL light will go on. The perfect solution is to blank the EGR by reprogramming the ECU.
Regards
Post #384964 4th Jan 2015 9:20pm
AlexSmith
Eduardo wrote:
Alex,
Cheers!
We've been there between January 4th and February 1st. Sad
But keep in touch! It would be a pleasure to meet you, Eduardo! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #404437 4th Mar 2015 2:29pm
AlexSmith
RafaBr wrote:
Alex
Regards
I'll try this as soon as I take it out of the garage again, Rafa! Will post the results here later. Thank for the hint! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
Post #404439 4th Mar 2015 2:31pm
Zouritte
Interesting stuff, I went to the dealer and as usual when you have the engeneer on board to show him the problem, it doesn't do it. But i described the symptoms and they proposed to change the fuel filter and add some kind of additive to remove the water that could be in the lines. And advised me to refuel with better fuel quality and so far the problem as been minimised not to say disappeared...
My EGR as been deactivated with a reprogramming of the ECU
Tim
Post #404450 4th Mar 2015 3:14pm
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Mine do only on sea level to!
Thought it was normal......
Post #406166 10th Mar 2015 2:16am
