Home > Technical > fitting a spare with RR offset ?
martyp1970
United Kingdom 2006 Defender 110 Td5 XS CSW Blenheim Silver
I have a 16" boost as a spare,
but if I wanted to fit a spare that is 20" off a range rover,
what are my options please,
thanks
Post #382877 29th Dec 2014 1:10am
K9F
Vague post....what wheels do you have fitted would be the obvious question? If they are 16" boosts I would delete this post to save embarrassment perhaps? The rolling radius of the spare must be as close to the wheel it is replacing, offset is not as important as long as it doesn't foul as a get you home only option..
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #382906 29th Dec 2014 9:05am
martyp1970
Sorry no embarrassment here,
im running 20" evoque ( style 6 I think ) original alloys,
with hub converters with hunter 4wheel alignment.
I still have a 16" boost as a 5th spare on the back ,
I have bought a single 20" for a spare but will it fit onto the oe spare wheel carrier ,with being different offset !!!
so if it wont fit as I said any ideas on something that will fit the rr alloy.
cheers
Post #382913 29th Dec 2014 9:16am
Rear spare wheel carriers are not expensive, and come up for sale on here from time to time. Consider buying a carrier and getting the bolts adjusted to match the rre spare
Can't be much more than an hours measuring and welding
Post #382915 29th Dec 2014 9:20am
grafty99
You could fit a carrier off a td5 discovery, wheel will bolt straight in without adapters Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #382921 29th Dec 2014 9:30am
K9F
I am a little confused myself, we are talking stud pattern, offset or both? I would suggest if both remove the studs off your original standard carrier have a reinforcing plate welded onto the face and then perhaps drill and refit the studs exactly where you need them.
Offset can often be adjusted by the adjustment spacer fitted to the original carrier studs to move it away from your wiper arm if required.
**Edit** Grafty's idea is better than mine. A lot less labour intensive..... Thumbs Up Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #382922 29th Dec 2014 9:31am
grafty99
The disco carrier bolts directly on to a defender rear door Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #382923 29th Dec 2014 9:31am
K9F
Stud pattern.....is it not the same? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #382925 29th Dec 2014 9:37am
martyp1970
cheers guys for replys,
what year of discovery carrier do I need.
Post #382926 29th Dec 2014 9:38am
grafty99
Anything in the lr range from 1998 on has the same pcd apart from the defender (I think) Any td5 disco should do it Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #382928 29th Dec 2014 9:44am
grafty99
The td5 disco has the smaller stud pattern in line with the rest of the lr range 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #382931 29th Dec 2014 9:47am
K9F
Thumbs Up
Learn something new everyday. Thanks Grafty. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #382935 29th Dec 2014 9:57am
martyp1970
Thanks again guys Razz
Post #382936 29th Dec 2014 9:59am
grafty99
K9F wrote:
Thumbs Up
No problem Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #382937 29th Dec 2014 10:00am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hi
Im running on Discovery 2 18" alloys on my defender (soon to be removed as i hate the hub adaptors!)
I recently fitted a spare wheel carrier, it had an adaptor fitted on the spare too, so it would fit, but then i had issues in the length of the wheel carrier bolts, all in all it was a bit of a headache having to shorten the studs on the new carrier which i was not too happy about doing!
I am doing away with them soon as if you need to do any work to hubs etc you have to remove adaptors too,
bit like taking 2 wheels off all the time.......simply cant be doing with it Evil or Very Mad
Still going with 18s but with Defender stud pattern! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #383120 29th Dec 2014 6:40pm
