Home > Td5 > got to fit a new rad. Are the alloy ones worth the extra
Orangeboy
I need to fit a new rad after I suspect the little pipe top right got broken by the muppets in my local garage ( but won't admit to it ).
Any way if in going to use my own time I want somthing that lasts so are the alloy ones worth the extra money
The engine is standard and little off road and some horse box towing.
At leat changing the noisy belt and tensioner will be easy with the rad removed lol
Sorry more questions
Is it worth changing the thermostat while its in bits ?
Or maybe even the pump
Oh all I see is ££££ now
Post #382156 26th Dec 2014 9:18pm
Are you sure the broken part can't be brazed back on again?
Post #382269 27th Dec 2014 11:18am
dorsetsmith
try tig Whistle
Post #382313 27th Dec 2014 2:05pm
munch90
you cant braze brass
have to be soldered or better silver solder , but you need a bl@@dy big soldering iron to repair a rad as the rad is made to get rid of heat !
unless its a late plastic rad !
Post #382318 27th Dec 2014 2:18pm
dorsetsmith wrote:
try tig Whistle
on an original rad???
Post #382385 27th Dec 2014 5:38pm
dorsetsmith
rad not made of aluminum Question posted TD5
Post #382387 27th Dec 2014 5:40pm
Orangeboy
maybe I was not very clear.
It's a 110 td5 and had a standard rad that's only 18 months old and now broken and I was wondering if the shiny alloy ones are worth the extra over a standard one
Post #382444 27th Dec 2014 8:08pm
dorsetsmith
my two have shiny alloy ones Mr. Green
Post #382447 27th Dec 2014 8:11pm
Orangeboy
this is where it's leaking. It seems the plastic pipe has craked from the end part of the rad
Post #382542 28th Dec 2014 7:55am
Fatboy Slim
Wales
Honestly, no I don't think it is worth the extra. Standard one performs fine, unless it's tuned to death and you fancy a trip to the sahara I wouldn't bother
Post #382594 28th Dec 2014 11:06am
