![]() | Home > Td5 > got to fit a new rad. Are the alloy ones worth the extra |
Are you sure the broken part can't be brazed back on again?
try tig
you cant braze brass
have to be soldered or better silver solder , but you need a bl@@dy big soldering iron to repair a rad as the rad is made to get rid of heat ! unless its a late plastic rad ! |
on an original rad??? |
rad not made of aluminum
Orangeboy Member Since: 24 Sep 2013 Location: Uk Posts: 48 ![]() |
maybe I was not very clear.
It's a 110 td5 and had a standard rad that's only 18 months old and now broken and I was wondering if the shiny alloy ones are worth the extra over a standard one |
my two have shiny alloy ones
![]() Click image to enlarge[/URL] this is where it's leaking. It seems the plastic pipe has craked from the end part of the rad Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Honestly, no I don't think it is worth the extra. Standard one performs fine, unless it's tuned to death and you fancy a trip to the sahara I wouldn't bother |
