Home > Maintenance & Modifications > Front Mudflaps Attachment Query |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
One of two things by the sounds of it.
First is a rivet (if the dome is totally smooth) in which case you will have to resort to the drill or a chisel to remove the head. The actual rubber flaps on my TD5 and Tdci are attached to the metal brackets with large rivets. Second could be a dome headed screw into a rivnut. If it is this you will have a receptor for some form of screwdriver/allen key in the dome. If it is this the rivnut is spinning so secure it with your mole grips and undo the screw. Then you need to drill out the rivnut and replace it. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
27th Dec 2014 5:13pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1172 |
Thanks Bob,
Either way it'll be getting some violent cutting tomorrow then Cheers G |
27th Dec 2014 10:04pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Pattern ones are nasty hammered over aluminium rivets, I cut through them with a sharp wood chisel cleaned and painted everything, then set screws and penny washers.
Keith |
27th Dec 2014 10:13pm |
