Home > Puma (Tdci) > Accelerating...
John051
Belgium 2010 Defender 110 Puma 2.4 XS CSW Java Black
Accelerating...
I'm the proud owner of a now 2 month old brand new 110 and have been following this forum for quite some time now. Always found answers to my questions on this forum until now... hence my first post. For about 2 days now I've noticed that, when I change gears (up) and put my foot back on the accelerator, there's some kind of a delay or lag (+/- 2 seconds). Is this normal? I push the accelerator down and it feels like nothing happens the first few seconds and then the car accelerates.
Anybody experienced this?
Post #38038 13th Aug 2010 3:27pm
jst
What did you drive before? are you coming completely up off the clutch? isint it part of the LR anti shunt things that came in with TD5 to stop too much power going in too soon after a gear change. What happens if you pull the multiplug on top of the clutch res. thats the only way the vehicle knows the clutch is in - i am led to believe. See if it still does it then. Or just apply power slightly later.
cant say i have ever had a problem with this but then i am not driving particularly briskley.
Do you notice it on other Pumas or just yours? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #38041 13th Aug 2010 3:44pm
John051
It's my first LD. I release the clutch completely before accelerating again. Just started noticing it 2 days again, it just feels off.
Post #38045 13th Aug 2010 4:28pm
K9F
Hello John051 and welcome to the site....
We could theoretically come up with a long list of possibilities for your symptom. Having sufferred similar I would personally suspect the well publicised EGR Valve. I would pop along to your dealers and thrash it out with them.
Mine sufferred the same and didn't throw up a latched fault for months I was always going to clean it but never got round to it. In the end I got a MIL light and a latched fault.
Look here:
http://www.defender2.net/forum/topic2227.html?highlight=egr+valve
Once sorted you could also consider fitting a blank:
http://www.defender2.net/forum/topic3115.html?highlight=blanks
Then again it could be something completely different. Question Question
Good luck and once again welcome. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38048 13th Aug 2010 5:03pm
John051
The EGR valve after only 2500 km, is that possible?
Post #38079 14th Aug 2010 6:59am
K9F
Yes! It only takes a miniscule bit of crud, grit or carbon to get them to start sticking! Read the thread links and get it to your dealer! At only two months old you do not have to worry or fret, let them sort it!
Post #38081 14th Aug 2010 7:43am
John051
OK, thanks for the advice! It's only a 2 minute drive from my house to the dealer so I'll see what they'll say next week.
Grt,
J
Post #38095 14th Aug 2010 10:34am
K9F
No excuses then!!! Thumbs Up
Even if they don't find any latched faults try and insist on an EGR Valve replacement it will discount it if the fault continues! With the history of EGR Valve problems it shouldn't be too difficult for them to agree. Let us know how you get on!
Good luck Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38096 14th Aug 2010 10:37am
Gav110
Australia
I had same on my brand new 110 - dealer said it was EGR. They had the car all last week - I get it back on TUE/WED. Gavster
2010 Puma 110
Post #38153 15th Aug 2010 11:04am
John051
Just got back from the dealer. Left the Landy there and they will try to figger out what's wrong with it tomorrow... I told the head mechanic about the EGR valve but he thinks it's unlikely that's the cause of the problem.
PS: After the problems I had at the end of last week and weekend the car drove perfectly to the dealer?
Grt,
J
Post #38255 16th Aug 2010 2:56pm
Gav110
Australia
I found that the EGR issue only shows up once the car is warm - when the temp needle is at/past halfway. The dealer confirmed this by saying that apparently below temp, the EGR operation is excluded as it could cause rough running when engine is cold.
Anyone else had similar experience? Gavster
2010 Puma 110
Post #38305 16th Aug 2010 11:33pm
K9F
John051 wrote:
... I told the head mechanic about the EGR valve but he thinks it's unlikely that's the cause of the problem. J
Not very experienced then! Or just not receptive to a customer coming up with a potential solution to a problem he as the head mechanic should be aware of? Do a search on here under EGR Valve, print it off, and shove it up his left nostril! Be interesting to see how unlikely he thinks it is then!
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38316 17th Aug 2010 7:13am
CapeLandy
South Africa
My EGR valve is being changed as we speak.
Mine starts when the car is cold in the morning and you can hear the drive motor chirping as if something metal is rubbing in the mechanism. Almost sounds like it is hunting for it's correct position. When you turn off the motor the cleaning cycle sounds like a bag of loose spanners. Shocked
The problems I had before the audible noise was a few jerks in the morning when cold, but this dissapeared after some time.
Post #38321 17th Aug 2010 8:11am
John051
Collected my Landy from the dealership this evening. They checked everything, did an extensive testdrive and a LR specialist (who happened to be there today) did a software update. They couldn't really find anything wrong... The drive home was OK and the car responded good to my gear changes - no lag. I made a deal with the head technician that, if the problem reoccurs, I could pop by to make him feel the lag.
Man, I missed her!
Gr,
J
Post #38372 17th Aug 2010 4:31pm
Naks
CL, how is your Puma since the EGR has been replaced? Better performance/consumption?
Post #38944 24th Aug 2010 7:55am
