Home > Technical > Lost all gears any ideas
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Having a good day! broke down 500yds from home when I lost all gears apart from 4th. Got home using low box but a little concerned. Had noticed a problem earlier in the day when selecting 3rd and reverse and first had nearly a foot of play! Only done 20-30 miles since it first showed.
Slightly concerned as put a new clutch and ashcroft recon box around 2k ago, but can only assume it's gearbox. Going to drop the oil out Monday and have a look but any ideas welcome.
Post #380577 20th Dec 2014 10:03pm
munch90
Possible gearlever selector bolt come loose , maybe in top housing on the box
have you got all gears in low box ? If so then problem shouldn't be in main box
if you got all gears in low range , then would say problem should be on high range side , but that wouldn't explain the odd gearlever problem
Post #380579 20th Dec 2014 10:15pm
Was going to mention splined shaft failiure but seeing as you mention 4th still available that rules that out.
Post #380580 20th Dec 2014 10:16pm
munch90
If our talking about td5 box ( as your profile ) then 4th gear is direct drive though the box , so problem could be on 2 motion shaft ( laygear )in the box , the drive runs though 2rd motion shaft for other gears
but then you should have 4th high range and 4th low range
Post #380585 20th Dec 2014 10:24pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
sounds like dropeed lay shaft to me new gearbox is needed or full re furb happened to my old td5 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #380588 20th Dec 2014 10:35pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Yep sounds like the end of the layshaft has snapped off inside the 5th gear housing.
Thats what happens when the big nut is done up with an airgun instead of being torqued up !
get the spanners out Big Cry 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #380592 20th Dec 2014 10:52pm
Sphere
All I can say is Big Cry
Post #380731 21st Dec 2014 4:40pm
Sphere
Well dropped the oil today and all was how it should be. No bits of metal and plenty of oil. So looking like the selector.
Post #381407 23rd Dec 2014 8:21pm
Sphere
Doctor google has suggested my problem will be the selector bolt come lose, ant this is a relatively simple fix? However I can't find any information / pictures on where and how to do this, would be grateful for any information.
Post #383593 31st Dec 2014 11:21am
