Home > Technical > Lost all gears any ideas |
Possible gearlever selector bolt come loose , maybe in top housing on the box
have you got all gears in low box ? If so then problem shouldn't be in main box if you got all gears in low range , then would say problem should be on high range side , but that wouldn't explain the odd gearlever problem Last edited by munch90 on 20th Dec 2014 10:20pm. Edited 1 time in total |
20th Dec 2014 10:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20489 |
Was going to mention splined shaft failiure but seeing as you mention 4th still available that rules that out.
20th Dec 2014 10:16pm |
If our talking about td5 box ( as your profile ) then 4th gear is direct drive though the box , so problem could be on 2 motion shaft ( laygear )in the box , the drive runs though 2rd motion shaft for other gears
but then you should have 4th high range and 4th low range |
20th Dec 2014 10:24pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
sounds like dropeed lay shaft to me new gearbox is needed or full re furb happened to my old td5 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
20th Dec 2014 10:35pm |
NickH Member Since: 01 Nov 2014 Location: Halifax Posts: 204 |
Yep sounds like the end of the layshaft has snapped off inside the 5th gear housing.
Thats what happens when the big nut is done up with an airgun instead of being torqued up ! get the spanners out 2003 Td5 90 2013 sport hse 2012 700 raptor quad 2012 siromer 4x4 tractor |
20th Dec 2014 10:52pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
All I can say is
21st Dec 2014 4:40pm |
Well dropped the oil today and all was how it should be. No bits of metal and plenty of oil. So looking like the selector.
23rd Dec 2014 8:21pm |
Doctor google has suggested my problem will be the selector bolt come lose, ant this is a relatively simple fix? However I can't find any information / pictures on where and how to do this, would be grateful for any information.
31st Dec 2014 11:21am |
