![]() | Home > Td5 > Wheel bearings going? If so? |
Jack up that wheel and feel for free play. If there is movement you could change to the old system or replace the bearings.
I do one wheel at the time (because I am a cheap ![]() ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
Why change the bearings if there's nothing wrong with them?
Uncas |
There could be play before bearings are getting bad.
When there is no grease they make noise, but if there are getting bad normally they start making noise while cornering. Do you have worn brake pads or a small stone between the brake disc and the splash plate on the inside off the barke disc? Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
That was my original thought. But would what else can give these symptoms? It would eliminate them from the equation. Having never experienced bad bearings ,(Other than a gp14 boat trailer which had been by the sea too long)I don't know what to expect. I did a search on Google and read some frightening story's of glowing hubs and welded jobbys
Just have a check on your propshaft UJ's before you get to carried away with wheel bearings. Allways look at the obvious first.
I have a bit of slop(normal i think) in the drive line. The prop shafts were dropped and checked about 3500 miles back. The 110 behaves its self on left hand bends and in a straight line, its just right handed-er under power.
sorry Roel I missed this.(my very slow typing) "There could be play before bearings are getting bad. When there is no grease they make noise, but if there are getting bad normally they start making noise while cornering. Do you have worn brake pads or a small stone between the brake disc and the splash plate on the inside off the barke disc? Roel " There is some good rattle coming from the rear pads as norm for 110s as they dont have anti rattel springs like the 90s, pads are good. I haven't checked for stones but will(did not see anything out of place today at the tire fitters). Range Rover p38 4.6 99 lpg(gone ![]() ![]() Last edited by Stue5 on 18th Dec 2014 10:46pm. Edited 1 time in total |
I know it sounds a bit off mentioning the props but it doesn't hurt totally ruling them out, right hand turns under power could be giving the osf wheel the least amount of adhesion as the weight is being transferred to the nsr of the vehicle. Under these circumstances it could even be your TC kicking in, I can get the TC lit up on my Td5 with some 'enthusiastic' driving on tarmac.
I did think this too, but the light dose not come on and I don't feel like i am any were the limit of the tires... i have tried to get a similar response on left hand bend but nothing. I had a badly balanced spare on my osf and linked with poor/cold road surface and old GGtr but today fresh new tires & inner-tubes all round balance correct pressure
![]() Thanks JWL i will have a l look tomorrow. Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Could it be the CV joint on that side..?
No idea how you check, perhaps someone else does...? Cheers Simon |
A sign that the cv's were on the way out on a Early Range Rover was noise at car park speed on full lock more klunky than I am experiencing(this I remeber from many years ago
![]() ![]() If I pull the fuse on the TC/ABS to eliminate the TC, this should work. Range Rover p38 4.6 99 lpg(gone ![]() ![]() |
you can get noise form a faulty wheel bearing without any play or movement at all
Found this two http://www.defender2.net/forum/topic19393.html?highlight=cv+noise http://www.defender2.net/forum/topic10240....p;start=15
The one with the sound recording sounds nothing like mine ![]() ![]() ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
If you can't find anything else amiss, I'd be inclined to drop out the front diff. You will have a two-gear (single cross-pin) diff, and these are known for wear, especially on 110 and 130 vehicles (the reason why they have now been superseded by 4-gear (two pin) diffs on LWB TDCis). It is not inconceivable that altered behaviour turning left as opposed to right is caused by the diff failing. |
