![]() | Home > Maintenance & Modifications > V8 engine options |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Best option if it was me
Find a late Disco 1 with a 3.9 Thor engine (serpentine belts) You will then have the Ecu,loom etc etc, to swap over (plus the auto box ![]() Forget going P38 lump,, the 4.6 had known block problems, plus you would need to sort a engine management system out, like Megasquirt or simalar California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Late Disco 1 route...
or Go 50th Anniversary defender / P38 Range Rover route with 4.0 or 4.6. The latter is how mine is done. Plug and play rather than joining wires and hoping it works long term. yes there are some negatives, but you can get an old 3.9 from a Disco that blows its head gasket soon after refitting. 50thdefender loom(RHD Japan) is what I have. It contains, engine, autobox looms. Then 50th Defender bulkhead loom has wing looms already in it, similair to Td5. I've updated the dash centre and warning lamps, really easy, just need to be patient and methodical. |
Is it burning much oil and smoking? I had a similar experience with #5 cylinder and it was due to the valve stem guides. It smoked blue on start up and as a result used a little oil but did not smoke or burn oil on the run. I was advised to leave well alone until it started burning oil all the time. The only drawback was that due to excessive carbon build up on that cylinder I had to remove and clean that sparkplug on a regular basis. Lasted another three years like that. If you go through life with your head in the sand....all people will see is an ar5e!!
Fozzauk Member Since: 05 Feb 2014 Location: Derbyshire Posts: 268 ![]() ![]() ![]() |
If you give it some good gas on start up then it throws out quite a cloud of black smoke.Seems fine when running and warm though?
I bought it as a project from a guy on disco3 so haven't run it long enough to see how much oil it's burning through. On the plus side it passed the MOT only needing a number plate light. I quite like the idea of going down the 50th anniversary route, as Romadog said i'm concerned about an old disco engine blowing soon after fitting and having to start again. Are the 50th looms readily available? |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
Black smoke is air to fuel ratio. Blue smoke oil.
Uncas |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 531 ![]() |
If changing the engine and reliability matters - then no question go the 3.9/4.0 efi the rest are over stressed and suffer more from slipped liners etc
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 333 ![]() ![]() ![]() |
3.9 is physically a straight swap, did that with my first 110. Also if you get the loom and ecu with the engine then fitting the whole efi system is not too difficult, there are usually a few wires in the loom that will not be needed in the Defender application.
The main challenges are arranging the air inlet plumbing along with airflow meter and filter and providing the high pressure fuel supply from the tank. TBH the carbs are a right pain to keep in balance and using an efi system results in a much smoother running engine with better economy (until you use the right foot ![]() I started out with a standard 110v8 with Stromburg carbs, then tried SUs, went to using an early efi setup off a classic RR, then when that engine died, fitted a 3.9 with the hotwire efi system. ![]() |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
this is the one im putting in mine
![]() still no idea of the problems im yet to encounter lol. ignorance is bliss. ![]() Click image to enlarge |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
I think you would be better off having a EFI v8 (3.9-4.6) with the later serpentine belt. There will be a few changes coming from a 3.5 carb but the it is worth the effort. JE Developments sells a stand alone harness in case you go 14CUX. m
dazzx10r Member Since: 26 Nov 2014 Location: Rotherham Posts: 17 ![]() ![]() ![]() |
stick a chevy LS in there job done
![]() ![]() At the end of the day it's all down to how far you're prepared to go with it. |
At the moment I am leaning towards a 5.0litre tvr chimera engine I have seen. I have quite a few spares for my wildcat with pretty much the same engine so this makes sense with my man logic.
![]() Anyone done this before or have any advice on going this route? |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
X2 for the TVR .
