Home > Maintenance & Modifications > V8 engine options
Page 3 of 3 <123
Jim G
United Kingdom 1984 Defender 90 300 Tdi HT Stornoway Grey
Do you only have the engine and ECU ?
I know nothing about the TVR rover V8 but would presume that they would use all the same sensors as they are using the 14 CUX
If so wouldn't the Disco 1 ( 14CUX) V8 ECU loom work as it is separate from the main loom , so is easy to get out and connects with just 4 wires ( on YOU TUBE )
If you have the correct ECU for the TVR then thats that !
The Megasquirt route is a long one ! big learning curve and then programming !
The 14 CUX IS also reprogrammable , so if its the wrong one you can probably still use it. 1984 300TDi hardtop Stornoway Grey
1984 200TDi hardtop..... soon to be a V8 .. but which V8 ?
1974 DAF T244 4x4 wagon converted to a motorhome
1976 Jaguar XJC with supercharged engine
Post #606875 5th Mar 2017 10:33am
mikeh501
Megasquirt! Having fun with mine and I haven't even got very far lol!!!! Learning curve is correct.
Post #606879 5th Mar 2017 10:53am
Page 3 of 3 <123
